network port vlan delete
Delete a virtual LAN (VLAN)
The network port vlan delete command deletes a VLAN from a network port.
Note When you delete a VLAN port, it is automatically removed from all failover rules and groups that use it.
-node {<nodename>|local} - Node
The node from which the VLAN is to be deleted.
{ -vlan-name {<netport>|<ifgrp>} - VLAN Name
The name of the VLAN that is to be deleted
| -port {<netport>|<ifgrp>} - Associated Network Port
The network port to which the VLAN is to be attached.
-vlan-id <integer> - Network Switch VLAN Identifier }
The ID tag of the deleted VLAN.
This example shows how to delete VLAN e1c-80 from network port e1c on node1.
cluster1::> network port vlan delete -node node1 -vlan-name e1c-80
