system controller fru show-manufacturing-info
Display manufacturing information of FRUs
The system controller fru show-manufacturing-info command displays manufacturing information for field replaceable units (FRUs) installed in the system. The information includes FRU-description, serial number, part number, and revision number. To display more details, use the -instance parameter.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
Displays detailed information about the installed FRUs in the system.
[-node {<nodename>|local}]- Node-
Selects a specific node's installed FRUs.
[-system-sn <text>]- System Serial Number-
Selects information about installed FRUs with the specified system serial number.
[-model-name <text>]- Model Name-
Selects information about installed FRUs with the specified model name.
[-system-id <text>]- System ID-
Selects information about installed FRUs with the specified system ID.
[-kernel-version <text>]- Kernel Version-
Selects information about installed FRUs with the specified kernel version.
[-firmware-release <text>]- Firmware Release-
Selects information about installed FRUs with the specified firmware release.
[-description <text>]- FRU Description-
Selects information about installed FRUs with the specified FRU description.
[-fru-subtype <text>]- FRU Sub-type-
Selects information about the FRU with the specified FRU subtype.
[-serial-number <text>]- FRU Serial Number-
Selects information about the FRU with the specified serial number.
[-part-number <text>]- FRU Part Number-
Selects information about the FRU with the specified part number.
[-revision <text>]- FRU Revision of Part Number-
Selects information about the FRU with the specified revision.
[-manufacturer <text>]- FRU Manufacturer-
Selects information about the FRU with the specified manufacturer.
[-manufacture-date <text>]- FRU Manufacturing Date-
Selects information about the FRU with the specified manufacture date.
[-product-id <text>]- FRU Product Identifier-
Selects information about the FRU with the specified product ID.
[-firmware-version <text>]- FRU Firmware Version-
Selects information about the FRU with the specified firmware version.
The following example displays all installed FRUs in the system:
cluster1::> system controller fru show-manufacturing-info
Node: platsw-lodi-1-01
System Serial Number: 791541000047
Model Name: FAS9040
System ID: 0537024373
Firmware release: 10.0X18
Kernel Version: NetApp Release sysMman_3887886_1608151712: Mon Aug 15
15:54:00 PDT 2016
FRU Description FRU Serial Number FRU Part Number FRU Rev.
Mother Board 031537000390 111-02419 40
Chassis 031536000252 111-02392 40
DIMM-1 CE-01-1510-02A8DC73 SHB722G4LML23P2-SB -
DIMM-3 CE-01-1510-02A8DCCC SHB722G4LML23P2-SB -
DIMM-8 CE-01-1510-02A8DE54 SHB722G4LML23P2-SB -
DIMM-9 CE-01-1510-02A8DE1C SHB722G4LML23P2-SB -
DIMM-11 CE-01-1510-02A8DF42 SHB722G4LML23P2-SB -
DIMM-16 CE-01-1510-02A8DD9B SHB722G4LML23P2-SB -
FAN1 031534001263 441-00058 40
FAN2 031534001292 441-00058 40
FAN3 031534001213 441-00058 40
PSU1 PSD092153200591 114-00146 40
PSU3 PSD092153200700 114-00146 40
mSATA boot0 1439100B02C3 - MU03
1/10 Gigabit Ethernet Controller IX4-T 031538000121 111-02399 40
QLogic 8324 10-Gigabit Ethernet Controller 031535000664 111-02397 40
NVRAM10 031537000846 111-02394 40
NVRAM10 BATT 31534000932 NetApp, Inc. 111-02591
NVRAM10 DIMM CE-01-1510-02A8DC03 SHB722G4LML23P2-SB -
PMC-Sierra PM8072 (111-02396) 031537000246 111-02396 41
PMC-Sierra PM8072 (111-02396) 031537000179 111-02396 41
Disk Serial Number PNHH1J0B X421_HCOBD450A10 -
Disk Serial Number PNHH2BKB X421_HCOBD450A10 -
Disk Serial Number PNHJPZ8B X421_HCOBD450A10 -
Disk Serial Number PNHG6SKB X421_HCOBD450A10 -
Disk Serial Number PNHKJYTB X421_HCOBD450A10 -
Disk Serial Number PNHSVMEY X421_HCOBD450A10 -
Disk Serial Number PNHT8KWY X421_HCOBD450A10 -
Disk Serial Number PNHSVL0Y X421_HCOBD450A10 -
Disk Serial Number PNHG5RHB X421_HCOBD450A10 -
Disk Serial Number PNHEXLWB X421_HCOBD450A10 -
Disk Serial Number PNHT8LJY X421_HCOBD450A10 -
Disk Serial Number PNHSVKZY X421_HCOBD450A10 -
DS2246 6000113106 0190 -
DS2246-Pwr-Supply XXT111825308 114-00065+A0 9C
DS2246-Pwr-Supply XXT111825314 114-00065+A0 9C
DS2246-MODULE 8000675532 111-00690+A3 23
DS2246-MODULE 8000751790 111-00690+A3 23
DS2246-CABLE 512130075 112-00430+A0 -
DS2246-CABLE - - -
DS2246-CABLE 512130118 112-00430+A0 -
DS2246-CABLE - - -
49 entries were displayed.
