storage aggregate show-resync-status
Display aggregate resynchronization status
The storage aggregate show-resync-status command displays resync status information for each plex. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all aggregates:
Aggregate Name
Resyncing Plex Name
Resyncing Percentage
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-aggregate <aggregate name>]- Aggregate-
This parameter specifies the name of the aggregate.
[-plex <text>]- Plex Name-
This parameter specifies the name of the plex.
[-status <text>]- Status-
Displays plex status. Possible values are:
normal -
failed -
empty -
invalid -
uninitialized -
failed assimilation -
limbo -
active -
inactive -
resyncing
These values may appear by themselves or in combination separated by commas; for example, "
normal,active". -
[-is-online {true|false}]- Is Online-
Indicates whether the plex is online.
[-in-progress {true|false}]- Resync is in Progress-
Indicates whether the plex is currently resyncing.
[-resyncing-percent <percent>]- Resyncing Percentage-
Displays the resynchronization completion percentage if the plex is currently being resynced, '-' otherwise.
[-resync-level <integer>]- Resync Level-
Displays the resync level if the plex is currently being resynced, '-' otherwise.
[-pool <integer>]- Pool-
The pool number to which the majority of disks in the plex belong.
The following example displays resynchronization status for all the aggregates:
cluster1::> storage aggregate show-resync-status
Complete
Aggregate Resyncing Plex Percentage
aggr0 plex0 -
aggr1 plex0 -
aggr1 plex1 10.00
aggr2 plex0 -
aggr2 plex2 -
5 entries were displayed.
