system node virtual-machine hypervisor modify-credentials
Modify hypervisor IP address and its credentials
The system node virtual-machine hypervisor modify-credentials command is used to set the IP address of the hypervisor on which the node is running or vSphere credentials (i.e. -new-username or -new-password ).
- -node {<nodename>|local}- Node
Name of the Data ONTAP node running in a virtual machine. It is a required field and the node must exist in the cluster.
- [-new-server <text>]- New Hypervisor IP Address
New vSphere server controlling this virtual machine. It can be either an IP address or (if name resolution is enabled) a hostname.
- [-new-username <text>]- New Hypervisor Username
New vSphere username for the -new-serverspecified above.
- [-new-password <text>]- New Hypervisor Password
New vSphere password for the -new-serverspecified above.
The following example sets the IP address and the credentials of the vSphere server on which the node is running.
cluster1::> system node virtual-machine hypervisor modify-credentials -node node1 -new-server 192.168.0.1 -new-username admin -new-password pass123
 PDFs
PDFs
