vserver services ndmp restartable-backup delete
Delete an NDMP restartable backup context
The vserver services ndmp restartable-backup delete
command deletes an NDMP restartable backup context. The -force
flag can be used to forcibly destroy a NDMP restartable backup context.
-vserver <Vserver Name>
- Vserver-
This parameter specifies the name of the Vserver for which NDMP restartable backup context is to be deleted.
-context-id <UUID>
- Context Identifier-
This parameter specifies the NDMP restartable backup context ID which needs to be deleted.
[-force <true>]
- Force Delete (privilege: advanced)-
If this parameter is specified, the context is deleted even if there are internal errors.
The following example shows how to delete an NDMP restartable backup context:
cluster1::> vserver services restartable-backup delete -vserver cluster1-01 -context-id 0f8f5c44-d540-11e5-8c45-005056963504 cluster1::>
