network fcp topology show
FCP topology interconnect elements per adapter
Display FCP topology interconnect elements per adapter.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Use this parameter to select the interconnect elements for adapters that are located on the node that you specify.
[-adapter <text>]- Adapter-
Use this parameter to select the interconnect elements for the specified adapter.
[-domain-id <integer>]- Domain Id-
Use this parameter to select the interconnect elements with the specified domain identifier.
[-port-wwpn <text>]- Port WWPN-
Use this parameter to select the interconnect elements with the specified port world wide name.
[-switch-name <text>]- Switch Name-
Use this parameter to select the interconnect elements with the specified switch.
[-switch-vendor <text>]- Switch Vendor-
Use this parameter to select the interconnect elements with the specified vendor.
[-switch-release <text>]- Switch Release-
Use this parameter to select the interconnect elements with the specified release.
[-switch-wwn <text>]- Switch WWN-
Use this parameter to select the interconnect elements with the specified world wide name.
[-port-count <integer>]- Port Count-
Use this parameter to select the interconnect elements with the specified port count.
[-port-slot <text>]- Port Slot-
Use this parameter to select the interconnect elements with the specified port slot.
[-port-state {Unknown|Online|Offline|Testing|Fault}]- Port State-
Use this parameter to select the interconnect elements with the specified port state.
[-port-type {None|N-Port|NL-Port|FNL-Port|NX-Port|F-Port|FL-Port|E-Port|B-Port|TNP-Port|TF-Port|NV-Port|FV-Port|SD-Port|TE-Port|TL-Port}]- Port Type-
Use this parameter to select the interconnect elements with the specified port type.
[-port-attached-wwpn <text>]- Attached Port WWPN-
Use this parameter to select the interconnect elements with the specified attached wwpn.
[-port-attached-id <text>]- Attached Port Id-
Use this parameter to select the interconnect elements with the specified attached id.
[-port-attached-visible <text>]- Visible-
Use this parameter to select the interconnect elements with the specified visiblity flag on attached port structure.
cluster1::> network fcp topology show
Switch connected to the adapter 0c
Switch Name: ssan-fc0e-d58
Switch Vendor: Cisco Systems, Inc.
Switch Release: 5.2(1)N1(9)
Switch Domain: 4
Switch WWN: 20:05:00:05:9b:26:f4:c1
Port Count: 20
Port Port WWN State Type Attached WWPN Port Id
vfc9 20:08:00:05:9b:26:f4:ff Offline None - -
vfc10 20:15:00:05:9b:26:f4:ff Online TF-Port 50:0a:09:82:8d:92:4c:ff 0x0407c0 *
vfc11 20:16:00:05:9b:26:f4:ff Online TF-Port 50:0a:09:81:8d:e2:4e:ec 0x040800 *
Switch Domain: 4
Port Count: 20
vfc20 20:13:00:05:9b:26:f4:ff Offline None - -
vfc21 20:14:00:05:9b:26:f4:ff Online TF-Port 50:0a:09:81:8d:92:4c:ff 0x0407a0 *
5 entries were displayed.
The example above show FCP topology interconnect information for the cluster.
