storage switch show
Display switch information
The storage switch show command displays information about all the storage switches in the MetroCluster configuration. The back-end switches must have been previously added for monitoring using the storage switch add command. If no parameters are specified, the default command displays the following information about the storage switches:
Switch
Symbolic Name
Vendor
Model
Switch WWN
Is Monitored
Monitor Status
To display detailed profile information about a single storage switch, use the -switch-name parameter.
- { [-fields <fieldname>,…]
Displays the specified fields for all the storage switches, in column style output.
- | [-connectivity ]
Displays the following details about the connectivity from the storage switch to connected entities: -
Port name
Port operating mode
Port world wide name
Peer port world wide name
Peer type
Additional information about peer
 Displays the following details about the connectivity from the node to the storage switch: -
Node name
Adapter name
Switch port name
Switch port speed
Adapter type
- | [-cooling ]
Displays the following details about the fans and temperature sensors on the storage switch: -
Fan name
Fan speed in rotations per minute (RPM)
Fan operational status
Temperature sensor name
Temperature sensor reading in Celsius ©
Temperature sensor status
- | [-error ]
Displays the errors related to the storage switch.
- | [-port ]
Displays the following details about the storage switch ports: -
Port name
Port administrative status
Port operational status
Port operating mode
Whether SFP is present in the port
Port speed in gigabits per second (Gbps)
Port BB credit
- | [-power ]
Displays the following details about the storage switch power supplies: -
Power supply name
Power supply serial number
Power supply operational status
- | [-san-config ]
Displays the following details about the Virutal Storage Area Networks (VSAN) and Zones of the storage switch: -
VSAN identifier
VSAN name
VSAN operational status
Type of load balancing configured for the VSAN
Where in-order-delivery set for the VSAN
Whether the auto power reset of the PSU is enabled
VAN member switch name and port
Zone name
VSAN ID of the zone
Zone member switch name and port
Zone member port id
Zone member port world wide name
- | [-sfp ]
Displays the following details about the storage switch ports Small Formfactor Pluggable (SFP): -
Port name
Type of SFP
SFP transmitter type
SFP vendor
SFP part number
SFP serial number
- | [-stats ]
Port name
Frames received through the port (Rx Frames)
Frames transmitted through the port (Tx Frames)
Octets received through the port (Rx Octets)
Octets transmitted through the port (Tx Octets)
Port error frames
- | [-instance ]}
Displays expanded information about all the storage switches in the system. If a storage switch is specified, then this parameter displays the same detailed information for the storage switch you specify as does the -switch-name parameter.
- [-switch-name <text>]- FC Switch Name
Displays information only about the storage switches that match the name you specify.
- [-switch-wwn <text>]- Switch World Wide Name
Displays information only about the storage switches that match the switch wwn you specify.
- [-switch-symbolic-name <text>]- Switch Symbolic Name
Displays information only about the storage switches that match the switch symbolic name you specify.
- [-switch-fabric-name <text>]- Fabric Name
Displays information only about the storage switches that match the switch fabric you specify.
- [-domain-id <integer>]- Switch Domain ID
Displays information only about the storage switches that match the switch domain id you specify.
- [-switch-role {unknown|primary|subordinate}]- Switch Role in Fabric
Displays information only about the storage switches that match the switch role you specify.
- [-snmp-version {SNMPv1|SNMPv2c|SNMPv3}]- SNMP Version
Displays information only about the storage switches that match the switch SNMP version you specify.
- [-switch-model <text>]- Switch Model
Displays information only about the storage switches that match the switch model you specify.
- [-switch-vendor {unknown|Brocade|Cisco}]- Switch Vendor
Displays information only about the storage switches that match the switch vendor you specify.
- [-fw-version <text>]- Switch Firmware Version
Displays information only about the storage switches that match the switch firmware version you specify.
- [-serial-number <text>]- Switch Serial Number
Displays information only about the storage switches that match the switch serial number you specify.
- [-switch-ipaddress <IP Address>]- Switch IP Address
Displays information only about the storage switches that match the switch IP address you specify.
- [-switch-status {unknown|ok|error}]- Switch Status
Displays information only about the storage switches that match the switch status you specify.
- [-snmp-community <text>]- (DEPRECATED)-SNMPv2c Community or SNMPv3 Username
This parameter is deprecated and may be removed in a future release of Data ONTAP. Use -snmp-community-or-usernameinstead.Displays information only about the storage switches that match the switch SNMPv2c community or SNMPv3 username you specify.
- [-snmp-community-or-username <text>]- SNMPv2c Community or SNMPv3 Username
- [-profile-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Profile Data Last Successful Refresh Timestamp
Displays information only about the storage switches that match the profile data last successful refresh timestamp you specify.
- [-is-monitoring-enabled {true|false}]- Is Monitoring Enabled for Switch
Displays information only about the storage switches that match the switch monitoring value you specify.
- [-blades <integer>,…]- Director-Class Switch Blades to Monitor
Displays information only about the storage switches that match the blade value you specify.
- [-engine-id <Hex String>]- Engine ID of SNMPv3 Capable Switch
Displays information only about the storage switches that match the SNMPv3 engine-id you specify.
- [-psu-name-list <text>,…]- Switch Power Supply Name List
Displays information only about the storage switches that have the power supply units with the names you specify.
- [-psu-serial-number-list <text>,…]- Switch Power Supply Serial Number List
Displays information only about the storage switches that have the power supply units with the serial numbers you specify.
- [-psu-status-list {unknown|normal|warning|faulty|not-present}]- Switch Power Supply Status List
Displays information only about the storage switches that have the power supply units with the statuses you specify.
- [-psu-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Power Supply Data Last Successful Refresh Timestamp
Displays information only about the storage switches that match the power supply unit data last successful refresh timestamp you specify.
- [-temp-sensor-name-list <text>,…]- Switch Temperature Sensor Name List
Displays information only about the storage switches that have the temperature sensors with the names you specify.
- [-temp-sensor-reading-list <integer>,…]- Switch Temperature Sensor Reading © List
Displays information only about the storage switches that have the temperature sensors with the readings you specify.
- [-temp-sensor-status-list {unknown|normal|warning|critical}]- Switch Temperature Sensor Status List
Displays information only about the storage switches that have the temperature sensors with the statuses you specify.
- [-temp-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Temperature Sensor Data Last Successful Refresh Timestamp
Displays information only about the storage switches that match the temperature sensor data last successful refresh timestamp you specify.
- [-fan-name-list <text>,…]- Switch Fan Name List
Displays information only about the storage switches that match the fans with the names you specify.
- [-fan-rpm-list <integer>,…]- Switch Fan Speed (RPM) List
Displays information only about the storage switches that match the fans with the RPM speeds you specify.
- [-fan-status-list {unknown|operational|failed|not-operational|not-present}]- Switch Fan Operational Status List
Displays information only about the storage switches that match the fans with the statuses you specify.
- [-fan-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Fan Data Last Successful Refresh Timestamp
Displays information only about the storage switches that match the fan data last successful refresh timestamp you specify.
- [-vsan-index-list <integer>,…]- Switch VSAN Index List
Displays information only about the storage switches that have the VSANs with the indexes you specify.
- [-vsan-name-list <text>,…]- Switch VSAN Name List
Displays information only about the storage switches that have the VSANs with the names you specify.
- [-vsan-oper-status-list {up|down}]- Switch VSAN Operational Status List
Displays information only about the storage switches that have the VSANs with the operational statuses you specify.
- [-vsan-load-balancing-type-list {src-id-dest-id|src-id-dest-id-ox-id}]- Switch VSAN Load balancing Type List
Displays information only about the storage switches that have the VSANs with the load balancing types you specify.
- [-is-vsan-iod-list {true|false}]- Is In-order Delivery Set for VSAN List
Displays information only about the storage switches that have the VSANs with the IOD setting you specify.
- [-vsan-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch VSAN Data Last Successful Refresh Timestamp
Displays information only about the storage switches that match the VSAN data last successful refresh timestamp you specify.
- [-member-switch-name-list <text>,…]- Member Switch List
Displays information only about the storage switches that have the VSANs with the member switch names you specify.
- [-member-switch-port-name-list <text>,…]- Member Switch Port Name List
Displays information only about the storage switches that have the VSANs with the memeber switch port names you specify.
- [-vsan-id-list <integer>,…]- Zone VSAN ID List
Displays information only about the storage switches that have the VSANs with the IDs you specify.
- [-zone-name-list <text>,…]- Switch Zone Name List
Displays information only about the storage switches that have the zones with the names you specify.
- [-zone-member-sw-domain-id-list <integer>,…]- Zone Member Switch Port Domain ID List
Displays information only about the storage switches that have the zones with the member switch domain ids you specify.
- [-zone-member-port-name-list <text>,…]- Zone Member Port List
Displays information only about the storage switches that have the zones with the port names you specify.
- [-zone-member-port-wwn-list <text>,…]- Zone Member WWPN List
Displays information only about the storage switches that have the zones with the port WWNs you specify.
- [-zone-member-port-switch-name-list <text>,…]- Zone Member Switch WWN List
Displays information only about the storage switches that have the zones with the member port hosting switch names you specify.
- [-zone-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Zone Data Last Successful Refresh Timestamp
Displays information only about the storage switches that match the zone data last successful refresh timestamp you specify.
- [-zone-member-wwn-list <text>,…]- Zone Member WWN List
Displays information only about the storage switches that have the zones with the member WWNs you specify.
- [-zone-member-port-id-list <text>,…]- Zone Member Port ID List
Displays information only about the storage switches that have the zones with the member port ids you specify.
- [-port-wwn-list <text>,…]- Switch Port World Wide Name (WWPN) List
Displays information only about the storage switches that have the ports with the WWNs you specify.
- [-port-name-list <text>,…]- Switch Port Name List
Displays information only about the storage switches that have the ports with the names you specify.
- [-port-admin-status-list {unknown|enabled|disabled}]- Switch Port Admin Status List
Displays information only about the storage switches that have the ports with administrative statuses you specify.
- [-port-oper-status-list {unknown|online|offline}]- Switch Port Operational Status List
Displays information only about the storage switches that have the ports with operational statuses you specify.
- [-port-mode-list {unknown|auto|F-port|FL-port|E-port|TE-port|U-port|G-port}]- Switch Port Mode List
Displays information only about the storage switches that have the ports with the operating modes you specify.
- [-port-oper-speed-list <integer>,…]- Switch Port Current Speed (in Gbits/sec) List
Displays information only about the storage switches that have the ports with the operational speeds you specify.
- [-port-bb-credit-list <integer>,…]- Switch Port BB Credit List
Displays information only about the storage switches that have the ports with the BB credits you specify.
- [-port-sfp-present-list {true|false}]- Switch Port Is SFP Present List
Displays information only about the storage switches that have the ports with the SFP present values you specify.
- [-port-peer-wwpn-list <text>,…]- Switch Port Peer WWPN List
Displays information only about the storage switches that have the ports with the peer port WWPNs you specify.
- [-port-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Port Data Last Successful Refresh Timestamp
Displays information only about the storage switches that match the port data last successful refresh timestamp you specify.
- [-port-stat-name-list <text>,…]- Switch Port Name List
- [-port-tx-frames-list <integer>,…]- Switch Port Transmitted Frame Count List
Displays information only about the storage switches that have the ports with the transmitted frames values you specify.
- [-port-rx-frames-list <integer>,…]- Switch Port Received Frame Count List
Displays information only about the storage switches that have the ports with the received frames values you specify.
- [-port-tx-octets-list <integer>,…]- Switch Port Total Transmitted Octets List
Displays information only about the storage switches that have the ports with the transmitted octets values you specify.
- [-port-rx-octets-list <integer>,…]- Switch Port Total Received Octets List
Displays information only about the storage switches that have the ports with the received octets values you specify.
- [-port-frame-error-list <integer>,…]- Switch Port Frame Error Count List
Displays information only about the storage switches that have the ports with the error frame values you specify.
- [-port-stat-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Port Stat Data Last Update Timestamp
Displays information only about the storage switches that match the port statistics data last successful refresh timestamp you specify.
- [-sfp-port-name-list <text>,…]- Switch Port Name List
- [-sfp-type-list {unknown|other|gbic|embedded|glm|gbic-with-serial-id|gbic-without-serial-id|sfp-with-serial-id|sfp-without-serial-id|xfp|x2-short|x2-medium|x2-tall|xpak-short|xpak-medium|xpak-tall|xenpak|sfp-dw-dm|qsfp|x2-dw-dm|gbic-not-installed|small-form-factor}]- Switch Port SFP Type List
Displays information only about the storage switches that have the ports with the SFP types you specify.
- [-sfp-tx-type-list {unknown|long-wave-laser|short-wave-laser|long-wave-laser-cost-reduced|electrical|ten-gig-base-sr|ten-gig-base-lr|ten-gig-base-er|ten-gig-base-lx4|ten-gig-base-sw|ten-gig-base-lw|ten-gig-base-ew}]- Switch Port SFP Transmitter Type List
Displays information only about the storage switches that have the ports with the SFP transmitter types you specify.
- [-sfp-vendor-list <text>,…]- Switch Port SFP Vendor List
Displays information only about the storage switches that have the ports with the SFP vendors you specify.
- [-sfp-part-number-list <text>,…]- Switch Port SFP Part Number List
Displays information only about the storage switches that have the ports with the SFP part numbers you specify.
- [-sfp-serial-number-list <text>,…]- Switch Port SFP Serial Number List
Displays information only about the storage switches that have the ports with the SFP serial numbers you specify.
- [-sfp-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Port SFP Data Last Successful Refresh Timestamp
Displays information only about the storage switches that match the port SFP data last successful refresh timestamp you specify.
- [-switch-error-text-list <text>,…]- Switch Error Text List
Displays information only about the storage switches that have the errors you specify.
- [-conn-switch-port-name-list <text>,…]- Switch Port Name List
- [-conn-switch-port-mode-list {unknown|auto|F-port|FL-port|E-port|TE-port|U-port|G-port}]- Switch Port Operating Mode List
- [-conn-switch-port-wwn-list <text>,…]- Switch Port WWN List
- [-conn-switch-port-peer-port-wwn-list <text>,…]- Switch Port Peer Port WWN List
Displays information only about the storage switches that have the ports with the peer port WWNs you specify.
- [-conn-switch-port-peer-info-list <text>,…]- Switch Port Peer Host & Port Name List
Displays information only about the storage switches that have the ports with the peer information values you specify.
- [-conn-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Connectivity Data Last Successful Refresh Timestamp
Displays information only about the storage switches that match the switch connectivity data last successful refresh timestamp you specify.
- [-conn-switch-port-peer-type-list {unknown|bridge|switch|fcp-adapter|fcvi-adapter}]- Switch Port Peer Type List
Displays information only about the storage switches that have the ports connected to the peer types you specify.
- [-switch-port-name-list <text>,…]- Switch Port Name List
- [-switch-port-speed-list <integer>,…]- Switch Port Speed (in Gbps) List
Displays information only about the storage switches that have the ports with the speeds you specify.
- [-node-name-list <nodename>,…]- Node Name List
Displays information only about the storage switches that are connected to the nodes you specify.
- [-adapter-name-list <text>,…]- Node Adapter Name List
Displays information only about the storage switches that are connected to the adapters you specify.
- [-adapter-port-name-list <text>,…]- Node Adapter Port Name List
Displays information only about the storage switches that are connected to the adapter ports you specify.
- [-adapter-type-list {unknown|FCP-Initiator|FC-VI|FCP-Target}]- Node Adapter Type List
Displays information only about the storage switches that are connected to the types of adapters you specify.
- [-path-data-last-successful-refresh-timestamp {MM/DD/YYYY HH:MM:SS [{+|-}hh:mm]}]- Switch Path Data Last Successful Refresh Timestamp
Displays information only about the storage switches that match the node to switch path data last successful refresh timestamp you specify.
- [-name-list <text>,…]- Switch Name List
Displays information only about the storage switches that match the names you specify.
- [-domain-id-list <integer>,…]- Switch Domain ID List
Displays information only about the storage switches that match the domain ids you specify.
- [-wwn-list <text>,…]- Switch WWN List
Displays information only about the storage switches that match the switch WWNs you specify.
- [-role-list {unknown|primary|subordinate}]- Switch Role in Fabric List
Displays information only about the storage switches that match the switch roles you specify.
- [-address-list <IP Address>,…]- Switch IP Address List
Displays information only about the storage switches that match the switch IP addresses you specify.
The following example displays information about all storage switches:
cluster::>storage switch show
                Symbolic                                     Is        Monitor
    Switch      Name     Vendor  Model      Switch WWN       Monitored Status
    Cisco_10.226.197.34
                mcc-cisco-8Gb-fab-4
                         Cisco   DS-C9148-16P-K9
                                            2000547fee78f088 true      ok
    Cisco_10.226.197.35
                mcc-cisco-8Gb-fab-3
                                            2000547fee78f0f0 true      ok
    Cisco_10.226.197.36
                mcc-cisco-8Gb-fab-2
                                            2000547fee78efb0 true      ok
    Cisco_10.226.197.37
                mcc-cisco-8Gb-fab-1
                                            2000547fee78f0d8 true      ok
    4 entries were displayed.
cluster::>
The following example displays connectivity (switch to peer and node to switch) information about all storage switches:
cluster::> storage switch show -connectivity
          Switch Name: Cisco_10.226.197.36
           Switch WWN: 2000547fee78efb0
           Fabric WWN: 2001547fee78efb1
               Vendor: Cisco
                Model: DS-C9148-16P-K9
               Errors: -
     Last Update Time: 7/31/2014 14:16:42 -04:00
Connectivity:
Port Name Port Mode Port WWN         Peer Port WWN    Peer Type    Peer Info
     fc1/1     F-port    2001547fee78efb0 2100001086607d34 unknown      unknown
     fc1/3     F-port    2003547fee78efb0 21000024ff3dd9cb unknown      unknown
     fc1/4     F-port    2004547fee78efb0 21000024ff3dda8d unknown      unknown
     fc1/5     F-port    2005547fee78efb0 500a0980009af880 unknown      unknown
     fc1/6     F-port    2006547fee78efb0 500a0981009af370 unknown      unknown
     fc1/11    TE-port   200b547fee78efb0 200b547fee78f088 switch       Cisco_10.226.197.34:fc1/11
     fc1/12    TE-port   200c547fee78efb0 200c547fee78f088 switch       Cisco_10.226.197.34:fc1/12
     fc1/13    F-port    200d547fee78efb0 2100001086609e22 unknown      unknown
     fc1/15    F-port    200f547fee78efb0 21000024ff3dd91b unknown      unknown
     fc1/16    F-port    2010547fee78efb0 21000024ff3dbef5 unknown      unknown
     fc1/17    F-port    2011547fee78efb0 500a0981009afda0 unknown      unknown
     fc1/18    F-port    2012547fee78efb0 500a0981009a9160 unknown      unknown
     fc1/25    F-port    2019547fee78efb0 21000010866037e8 bridge       ATTO_10.226.197.17:1
     fc1/27    F-port    201b547fee78efb0 21000024ff3dd9d3 fcvi-adapter dpg-mcc-3240-15-a1:fcvi_device_1
     fc1/28    F-port    201c547fee78efb0 21000024ff3dbe3d fcvi-adapter dpg-mcc-3240-15-a2:fcvi_device_1
     fc1/29    F-port    201d547fee78efb0 500a0980009ae0a0 fcp-adapter  dpg-mcc-3240-15-a2:0c
     fc1/30    F-port    201e547fee78efb0 500a0981009aef40 fcp-adapter  dpg-mcc-3240-15-a1:0d
Last Update Time: 7/31/2014 14:26:48 -04:00
Path:
                                                      Switch
                                                        Port
     Node                 Adapter        Switch Port   Speed Adapter Type
     dpg-mcc-3240-15-a1   0d             fc1/30        4Gbps FCP-Initiator
     dpg-mcc-3240-15-a1   fcvi_device_1  fc1/27        8Gbps FC-VI
     dpg-mcc-3240-15-a2   0c             fc1/29        4Gbps FCP-Initiator
     dpg-mcc-3240-15-a2   fcvi_device_1  fc1/28        8Gbps FC-VI
The following command displays cooling (temperature sensors and fans) information about all storage switches:
cluster::>storage switch show -cooling
Switch Name: Cisco_10.226.197.34
           Switch WWN: 2000547fee78f088
               Vendor: Cisco
              Errors: -
    Last Update Time: 7/31/2014 14:26:58 -04:00
Fans:
    Fan               RPM Status
    Fan Module-1        - operational
    Fan Module-2          operational
    Fan Module-3          operational
    Fan Module-4          operational
Last Update Time: 7/31/2014 14:27:10 -04:00
Temperature Sensors:
Sensor          Temp (C) Status
    module-1 Outlet       27 normal
    module-1 Outlet       29 normal
    module-1 Intake       26 normal
    module-1 Intake       28 normal
The following command displays the error information about all storage switches:
cluster::> storage switch show -error
    Cisco_10.226.197.34(2000547fee78f088): Switch is Unreachable over Management Network.
Switch Name: Cisco_10.226.197.35
     Switch WWN: 2000547fee78f0f0
    Cisco_10.226.197.35(2000547fee78f0f0): Switch is Unreachable over Management Network.
    Cisco_10.226.197.36(2000547fee78efb0): Switch is Unreachable over Management Network.
Switch Name: Cisco_10.226.197.37
     Switch WWN: 2000547fee78f0d8
    Cisco_10.226.197.37(2000547fee78f0d8): Switch is Unreachable over Management Network.
The following command displays the detailed information about all the storage switches:
cluster::> storage switch show -instance
       Switch Domain: -
         Switch Role: -
              Vendor: Cisco
    Firmware Version: 6.2(1)
       Management IP: 10.226.197.34
              Errors: Cisco_10.226.197.34(2000547fee78f088): Switch is Unreachable over Management Network.
    Last Update Time: 7/31/2014 14:41:28 -04:00
Fabric:
Switch Name                 Domain WWN              Role        IP Address
    Cisco_10.226.197.34              0 2000547fee78f088 unknown     10.226.197.34
    Cisco_10.226.197.36              0 2000547fee78efb0 unknown     10.226.197.36
The following command displays port information about all storage switches:
cluster::> storage switch show -port
               Vendor: Cisco
              Errors: -
Ports:
                       Admin    Oper              SFP      Speed     BB
    Port Name Port WWN Status   Status  Port Mode Present (Gbps) Credit PeerPortWWN
    fc1/1     2001547fee78f088
                       enabled  online  F-port    true         8      1 2100001086608b76
    fc1/2     2002547fee78f088
                       enabled  offline auto      true         0      1
    fc1/3     2003547fee78f088
                       enabled  online  F-port    true         8      1 21000024ff48edd9
    fc1/4     2004547fee78f088
                       enabled  online  F-port    true         8      1 21000024ff3dd981
    fc1/5     2005547fee78f088
                       enabled  online  F-port    true         4      1 500a098001057f98
    fc1/6     2006547fee78f088
                       enabled  online  F-port    true         4      1 500a098101069778
    fc1/7     2007547fee78f088
    fc1/8     2008547fee78f088
    fc1/9     2009547fee78f088
    fc1/10    200a547fee78f088
                       enabled  offline auto      true         0     32
    fc1/11    200b547fee78f088
                       enabled  offline TE-port   true         8     32 200b547fee78efb0
    fc1/12    200c547fee78f088
                       enabled  offline TE-port   true         8     32 200c547fee78efb0
    fc1/13    200d547fee78f088
                       enabled  online  F-port    true         8     32 2100001086609c2e
    fc1/14    200e547fee78f088
    fc1/15    200f547fee78f088
    fc1/16    2010547fee78f088
    fc1/17    2011547fee78f088
    fc1/18    2012547fee78f088
    fc1/19    2013547fee78f088
    fc1/20    2014547fee78f088
    fc1/21    2015547fee78f088
    fc1/22    2016547fee78f088
    fc1/23    2017547fee78f088
    fc1/24    2018547fee78f088
    fc1/25    2019547fee78f088
                       enabled  online  F-port    true         8     32 2100001086609c06
    fc1/26    201a547fee78f088
    fc1/27    201b547fee78f088
                       enabled  online  F-port    true         8     32 21000024ff48ea93
    fc1/28    201c547fee78f088
                       enabled  online  F-port    true         8     32 21000024ff48eacf
    fc1/29    201d547fee78f088
                       enabled  online  F-port    true         4     32 500a098101484340
    fc1/30    201e547fee78f088
                       enabled  online  F-port    true         4     32 500a09810147e700
    fc1/31    201f547fee78f088
    fc1/32    2020547fee78f088
    fc1/33    2021547fee78f088
    fc1/34    2022547fee78f088
    fc1/35    2023547fee78f088
    fc1/36    2024547fee78f088
    fc1/37    2025547fee78f088
    fc1/38    2026547fee78f088
    fc1/39    2027547fee78f088
    fc1/40    2028547fee78f088
    fc1/41    2029547fee78f088
    fc1/42    202a547fee78f088
    fc1/43    202b547fee78f088
    fc1/44    202c547fee78f088
    fc1/45    202d547fee78f088
    fc1/46    202e547fee78f088
    fc1/47    202f547fee78f088
    fc1/48    2030547fee78f088
                       enabled  offline auto      true         0      0
    port-channel 1
              2401547fee78f088
    port-channel 2
              2402547fee78f088
    port-channel 3
              2403547fee78f088
    port-channel 4
              2404547fee78f088
    port-channel 5
              2405547fee78f088
    port-channel 6
              2406547fee78f088
    port-channel 7
              2407547fee78f088
    port-channel 8
              2408547fee78f088
    port-channel 9
              2409547fee78f088
    port-channel 10
              240a547fee78f088
    port-channel 11
              240b547fee78f088
    port-channel 12
              240c547fee78f088
    sup-fc0            enabled  online  unknown   true         1      0
The following command displays power supply unit information about all storage switches:
cluster::> storage switch show -power
               Vendor: Cisco
              Errors: -
    Last Update Time: 7/31/2014 14:41:49 -04:00
Power Supplies:
Power Supply    Serial Number Status
    300.00W 110v AC PAC15494TBZ   normal
    300.00W 110v AC PAC15494T4D   normal
The following command displays san configuration (VSANs and Zones) information about all storage switches:
cluster::> storage switch show -san-config
               Vendor: Cisco
              Errors: -
    VSAN Configuration:
Oper
    VSAN ID Vsan Name                Status Load Balancing  isIOD
          1 VSAN0001                 up     src-id-dest-id  true
          2 dpg_13_storage           up     src-id-dest-id-ox-id
                                                            true
          3 dpg_13_fcvi              down   src-id-dest-id-ox-id
                                                            true
         10 dpg_mcc_13_fab1_fcvi     up     src-id-dest-id  true
         20 dpg_mcc_13_fab1_storage  up     src-id-dest-id-ox-id
                                                            true
         30 dpg_mcc_13_fab2_fcvi     up     src-id-dest-id  true
         40 VSAN0040                 up     src-id-dest-id  true
         70 dpg_mcc_14_fcvi          up     src-id-dest-id  true
         80 dpg_mcc_14_storage       up     src-id-dest-id-ox-id
                                                            true
        110 dpg_mcc_15_fcvi          up     src-id-dest-id-ox-id
                                                            true
        120 dpg_mcc_15_storage       up     src-id-dest-id-ox-id
                                                            true
       4094 isolated_vsan            down   src-id-dest-id-ox-id
                                                            true
VSAN Membership:
VSAN ID Switch Name          Switch Port Name
          1 Cisco_10.226.197.34  fc1/2
          1 Cisco_10.226.197.34  fc1/7
          1 Cisco_10.226.197.34  fc1/8
          1 Cisco_10.226.197.34  fc1/9
          1 Cisco_10.226.197.34  fc1/10
          1 Cisco_10.226.197.34  fc1/11
          1 Cisco_10.226.197.34  fc1/12
          1 Cisco_10.226.197.34  fc1/14
          1 Cisco_10.226.197.34  fc1/19
          1 Cisco_10.226.197.34  fc1/20
          1 Cisco_10.226.197.34  fc1/21
          1 Cisco_10.226.197.34  fc1/22
          1 Cisco_10.226.197.34  fc1/23
          1 Cisco_10.226.197.34  fc1/24
          1 Cisco_10.226.197.34  fc1/31
          1 Cisco_10.226.197.34  fc1/32
          1 Cisco_10.226.197.34  fc1/33
          1 Cisco_10.226.197.34  fc1/34
          1 Cisco_10.226.197.34  fc1/35
          1 Cisco_10.226.197.34  fc1/36
          1 Cisco_10.226.197.34  fc1/37
          1 Cisco_10.226.197.34  fc1/38
          1 Cisco_10.226.197.34  fc1/39
          1 Cisco_10.226.197.34  fc1/40
          1 Cisco_10.226.197.34  fc1/41
          1 Cisco_10.226.197.34  fc1/42
          1 Cisco_10.226.197.34  fc1/43
          1 Cisco_10.226.197.34  fc1/44
          1 Cisco_10.226.197.34  fc1/45
          1 Cisco_10.226.197.34  fc1/46
          1 Cisco_10.226.197.34  fc1/47
          1 Cisco_10.226.197.34  fc1/48
          1 Cisco_10.226.197.34  port-channel 1
          1 Cisco_10.226.197.34  port-channel 2
          1 Cisco_10.226.197.34  port-channel 3
          1 Cisco_10.226.197.34  port-channel 4
          1 Cisco_10.226.197.34  port-channel 5
          1 Cisco_10.226.197.34  port-channel 6
          1 Cisco_10.226.197.34  port-channel 7
          1 Cisco_10.226.197.34  port-channel 8
          1 Cisco_10.226.197.34  port-channel 9
          1 Cisco_10.226.197.34  port-channel 10
          1 Cisco_10.226.197.34  port-channel 11
          1 Cisco_10.226.197.34  port-channel 12
          1 Cisco_10.226.197.36  fc1/2
          1 Cisco_10.226.197.36  fc1/7
          1 Cisco_10.226.197.36  fc1/8
          1 Cisco_10.226.197.36  fc1/9
          1 Cisco_10.226.197.36  fc1/10
          1 Cisco_10.226.197.36  fc1/11
          1 Cisco_10.226.197.36  fc1/12
          1 Cisco_10.226.197.36  fc1/14
          1 Cisco_10.226.197.36  fc1/19
          1 Cisco_10.226.197.36  fc1/20
          1 Cisco_10.226.197.36  fc1/21
          1 Cisco_10.226.197.36  fc1/22
          1 Cisco_10.226.197.36  fc1/23
          1 Cisco_10.226.197.36  fc1/24
          1 Cisco_10.226.197.36  fc1/26
          1 Cisco_10.226.197.36  fc1/31
          1 Cisco_10.226.197.36  fc1/32
          1 Cisco_10.226.197.36  fc1/33
          1 Cisco_10.226.197.36  fc1/34
          1 Cisco_10.226.197.36  fc1/35
          1 Cisco_10.226.197.36  fc1/36
          1 Cisco_10.226.197.36  fc1/37
          1 Cisco_10.226.197.36  fc1/38
          1 Cisco_10.226.197.36  fc1/39
          1 Cisco_10.226.197.36  fc1/40
          1 Cisco_10.226.197.36  fc1/41
          1 Cisco_10.226.197.36  fc1/42
          1 Cisco_10.226.197.36  fc1/43
          1 Cisco_10.226.197.36  fc1/44
          1 Cisco_10.226.197.36  fc1/45
          1 Cisco_10.226.197.36  fc1/46
          1 Cisco_10.226.197.36  fc1/47
          1 Cisco_10.226.197.36  fc1/48
         30 Cisco_10.226.197.34  fc1/3
         30 Cisco_10.226.197.34  fc1/4
         30 Cisco_10.226.197.36  fc1/3
         30 Cisco_10.226.197.36  fc1/4
         40 Cisco_10.226.197.34  fc1/1
         40 Cisco_10.226.197.34  fc1/5
         40 Cisco_10.226.197.34  fc1/6
         40 Cisco_10.226.197.36  fc1/1
         40 Cisco_10.226.197.36  fc1/5
         40 Cisco_10.226.197.36  fc1/6
         70 Cisco_10.226.197.34  fc1/15
         70 Cisco_10.226.197.34  fc1/16
         70 Cisco_10.226.197.36  fc1/15
         70 Cisco_10.226.197.36  fc1/16
         80 Cisco_10.226.197.34  fc1/13
         80 Cisco_10.226.197.34  fc1/17
         80 Cisco_10.226.197.34  fc1/18
         80 Cisco_10.226.197.36  fc1/13
         80 Cisco_10.226.197.36  fc1/17
         80 Cisco_10.226.197.36  fc1/18
        110 Cisco_10.226.197.34  fc1/26
        110 Cisco_10.226.197.34  fc1/27
        110 Cisco_10.226.197.34  fc1/28
        120 Cisco_10.226.197.34  fc1/25
        120 Cisco_10.226.197.34  fc1/29
        120 Cisco_10.226.197.34  fc1/30
        120 Cisco_10.226.197.36  fc1/25
        120 Cisco_10.226.197.36  fc1/29
        120 Cisco_10.226.197.36  fc1/30
Last Update Time: 7/31/2014 14:45:40 -04:00
Zone Configuration:
   Member            Member      Member
   Zone Name VSAN ID Switch Name Port Name Port ID Member WWN
   dpg_mcc_fcvi   30 Cisco_10.226.197.36
                                 fc1/3     -
   $default_zone$ 30 Cisco_10.226.197.36
                                 fc1/4
   dpg_mcc_storage
                                 fc1/1
   $default_zone$ 40 Cisco_10.226.197.36
                                 fc1/5
   dpg_mcc_14_fcvi
                                 fc1/15
   $default_zone$ 70 Cisco_10.226.197.36
                                 fc1/16
   dpg_mcc_14_storage
                                 fc1/13
   $default_zone$ 80 Cisco_10.226.197.34
                                 fc1/17
   dpg_mcc_15_fcvi
                 110 Cisco_10.226.197.36
                                 fc1/27
   $default_zone$
                                 fc1/28
   dpg_mcc_15_storage
                                 fc1/25
   $default_zone$
                                 fc1/29
The following command displays port SFP information about all storage switches:
cluster::> storage switch show -sfp
               Vendor: Cisco
              Errors: -
SFP:
Port Name Type          Tx Type          Vendor      Part Number Serial Number
    fc1/1     sfp-with-serial-id
                            short-wave-laser CISCO-FINISAR
                                                          FTLF8528P2BCV-CS
        FNS160629J9
    fc1/2     unknown       unknown
    fc1/3     sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629H3
    fc1/4     sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629QH
    fc1/5     sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160628EA
    fc1/6     sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629QT
    fc1/7     unknown       unknown
    fc1/8     unknown       unknown
    fc1/9     unknown       unknown
    fc1/10    unknown       unknown
    fc1/11    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629GP
    fc1/12    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061X71
    fc1/13    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629P8
    fc1/14    unknown       unknown
    fc1/15    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629JP
    fc1/16    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160628D2
    fc1/17    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629NG
    fc1/18    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629R1
    fc1/19    unknown       unknown
    fc1/20    unknown       unknown
    fc1/21    unknown       unknown
    fc1/22    unknown       unknown
    fc1/23    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629NC
    fc1/24    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160628CX
    fc1/25    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629NZ
    fc1/26    unknown       unknown
    fc1/27    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061XB0
    fc1/28    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061XA6
    fc1/29    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061XA0
    fc1/30    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061X9S
    fc1/31    unknown       unknown
    fc1/32    unknown       unknown
    fc1/33    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS16061NL7
    fc1/34    unknown       unknown
    fc1/35    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629M8
    fc1/36    sfp-with-serial-id
                                                          FTLF8528P2BCV-CS
        FNS160629KH
    fc1/37    unknown       unknown
    fc1/38    unknown       unknown
    fc1/39    unknown       unknown
    fc1/40    unknown       unknown
    fc1/41    unknown       unknown
    fc1/42    unknown       unknown
    fc1/43    unknown       unknown
    fc1/44    unknown       unknown
    fc1/45    unknown       unknown
    fc1/46    unknown       unknown
    fc1/47    unknown       unknown
    fc1/48    unknown       unknown
    port-channel 1
              unknown       unknown
    port-channel 2
              unknown       unknown
    port-channel 3
              unknown       unknown
    port-channel 4
              unknown       unknown
    port-channel 5
              unknown       unknown
    port-channel 6
              unknown       unknown
    port-channel 7
              unknown       unknown
    port-channel 8
              unknown       unknown
    port-channel 9
              unknown       unknown
    port-channel 10
              unknown       unknown
    port-channel 11
              unknown       unknown
    port-channel 12
              unknown       unknown
    sup-fc0
The following command displays port statistics information about all storage switches:
cluster::> storage switch show -stats
               Vendor: Cisco
              Errors: -
Port Statistics:
                           Rx           Rx           Tx           Tx        Error
    Port Name          Frames       Octets       Frames       Octets       Frames
    fc1/1          2116207233   3710682580   3906335374    859905888            0
    fc1/2                   1          208            1          208            0
    fc1/3          3238899002    903116292   3079548736   4014304952            0
    fc1/4          1888758418   1643379900   2434821325   2997002344            0
    fc1/5          3719731908   1808138824   1878240211   3421335100            0
    fc1/6          2644430347   1042009564    249190625   2003353056            0
    fc1/7                   1          228            1          228            0
    fc1/8                   1          156            1          156            0
    fc1/9                   1          148            1          148            0
    fc1/10                  1          224            1          224            0
    fc1/11         3617142898   4129927136     39089396   2595464620            0
    fc1/12          473603889   1560909460   2797562521   2833496016            0
    fc1/13         1852255936   1091902804    180309704   1769859928            0
    fc1/14                  1          140            1          140            0
    fc1/15            4997082   3519688264      4283938   3370856432            0
    fc1/16            4995287   3519577592      4282173   3370732136            0
    fc1/17           55146756    178045212   1733567096   3030415436            0
    fc1/18           63005788   4287094736   1726651844   2640371212            0
    fc1/19                  1          200            1          200            0
    fc1/20                  1          104            1          104            0
    fc1/21                  1          108            1          108            0
    fc1/22                  1          108            1          108            0
    fc1/23                  1          164            1          164            0
    fc1/24                  1          216            1          216            0
    fc1/25         2810698819   1611009260    471527156   1900246656            0
    fc1/26                  1          104            1          104            0
    fc1/27         4165019838    887421780   3848122102   2581891136            0
    fc1/28           58607737   1015197080    101621078   3482734024            0
    fc1/29         4266270960    222242144   3766674764   2400640552            0
    fc1/30         3984658378   1443835508    152597387    678837848            0
    fc1/31                  1          220            1          220            0
    fc1/32                  1          120            1          120            0
    fc1/33                  1          132            1          132            0
    fc1/34                  1          144            1          144            0
    fc1/35                  1          160            1          160            0
    fc1/36                  1          104            1          104            0
    fc1/37                  1          148            1          148            0
    fc1/38                  1          184            1          184            0
    fc1/39                  1          160            1          160            0
    fc1/40                  1          136            1          136            0
    fc1/41                  1          196            1          196            0
    fc1/42                  1          128            1          128            0
    fc1/43                  1          168            1          168            0
    fc1/44                  1          212            1          212            0
    fc1/45                  1          136            1          136            0
    fc1/46                  1          224            1          224            0
    fc1/47                  1          104            1          104            0
    fc1/48                  1          104            1          104            0
 PDFs
PDFs
