vserver nfs kerberos interface show
Display the Kerberos configurations of NFS servers
The vserver nfs kerberos interface show
command displays information about Kerberos configurations for NFS. The command output depends on the parameters specified with the command. If you do not specify any parameters, the command displays the following information about all Kerberos configurations for NFS:
Vserver name
Logical interface name
Logical interface IP address
Whether Kerberos is enabled or disabled
The Kerberos service principal name (SPN)
The permitted encryption types
You can specify additional parameters to display only information that matches those parameters. For instance, to display information only about Kerberos configurations for NFS that are enabled, run the command with the -kerberos enabled
parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If you specify this parameter and the
-lif
parameter, the command displays information only about the Kerberos configuration or configurations for NFS that are associated with the specified Vserver and logical interface. [-lif <text>]
- Logical Interface-
-vserver
parameter, the command displays information only about the Kerberos configuration or configurations for NFS that are associated with the specified logical interface and Vserver. [-address <IP Address>]
- IP Address-
If you specify this parameter, the command displays information only about the Kerberos configurations for NFS that are associated with the specified logical-interface IP address.
[-kerberos {enabled|disabled}]
- Kerberos Enabled-
If you specify this parameter, the command displays information only about the Kerberos configurations for NFS that match the specified value.
[-spn <text>]
- Service Principal Name-
If you specify this parameter, the command displays information only about the Kerberos configuration or configurations for NFS that match the specified SPN.
[-permitted-enc-types <NFS Kerberos Encryption Type>,…]
- Permitted Encryption Types-
If you specify this parameter, the command displays information only about the Kerberos configuration for NFS that matches the specified encryption types.
[-machine-account <text>]
- Machine Account Name-
If you specify this parameter, the command displays information only about the Kerberos configuration for NFS that matches the specified machine account.
The following example displays information about the Kerberos configuration for NFS associated with the Vserver vs0 and the logical interface datalif1:
vs1::> vserver nfs kerberos interface show -vserver vs0 -lif datalif1 Vserver: vs1 Logical Interface: datalif1 IP Address: 192.0.2.130 Kerberos Enabled: enabled Service Principal Name: nfs/sec.example.com@AUTH.SEC.EXAMPLE.COM Permitted Encryption Types: des,des3,aes-128,aes-256
