ONTAP commands
snapmirror object-store profiler show
The snapmirror object-store profiler show command is used to monitor progress and results of the snapmirror object-store profiler start command.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - Node Name (privilege: advanced)
This parameter specifies the node on which the profiler was started.
[-object-store-name <text>] - ONTAP Name for this Object Store Configuration (privilege: advanced)
This parameter specifies the object store configuration that describes the object store. The object store configuration has information about the object store server name, port, access credentials, and provider type.
[-profiler-status <text>] - Profiler Status (privilege: advanced)
Current status of the profiler.
[-start-time <MM/DD/YYYY HH:MM:SS>] - Profiler Start Time (privilege: advanced)
Time at which profiler run started.
[-op-name <text>] - Operation Name - PUT/GET (privilege: advanced)
Name of the operation. Possible values are PUT or GET.
[-op-size {<integer>[KB|MB|GB|TB|PB]}] - Size of Operation (privilege: advanced)
Size of the PUT or GET operation.
[-op-count <integer>] - Number of Operations Performed (privilege: advanced)
Number of operations issued to the object store.
[-op-failed <integer>] - Number of Operations Failed (privilege: advanced)
Number of operations that failed.
[-op-latency-minimum <integer>] - Minimum Latency for Operation in Milliseconds (privilege: advanced)
Minimum latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-latency-maximum <integer>] - Maximum Latency for Operation in Milliseconds (privilege: advanced)
Maximum latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-latency-average <integer>] - Average Latency for Operation in Milliseconds (privilege: advanced)
Average latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-throughput {<integer>[KB|MB|GB|TB|PB]}] - Throughput per Second for the operation (privilege: advanced)
Throughput per second for the operation.
[-op-errors <text>,…​] - Error Reasons and Count (privilege: advanced)
Error reasons and count for failed operation.
[-op-latency-histogram <text>,…​] - Latency Histogram (privilege: advanced)
Latency histogram for the operation.
The following example displays the results of snapmirror object-store profiler start :
cluster1::>snapmirror object-store profiler show
