network connections active show-clients
Show a count of the active connections by client
The network connections active show-clients
command displays information about client connections, including the client’s IP address and the number of client connections.
The results of this command set are refreshed independently every 30 seconds and might not reflect the immediate state of the system. |
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Use this parameter to display information only about the connections on the node you specify.
[-vserver <vserver>]
- Vserver-
This parameter is used by the system to break down the output per vserver.
[-remote-address <Remote IP>]
- Remote IP Address-
Use this parameter to display information only about the connections that use the remote IP address you specify.
[-count <integer>]
- Client Count-
Use this parameter to only clients with the number of active client connections you specify.
The following example displays information about active client connections:
cluster1::> network connections active show-clients Node Vserver Name Client IP Address Count ------ -------------- ----------------- ------ node0 vs1 192.0.2.253 1 vs2 192.0.2.252 2 vs3 192.0.2.251 5 node1 vs1 192.0.2.250 1 vs2 192.0.2.252 3 vs2 customer.example.com 4
