      security protocol ssh show
Show the SSH configuration
The security protocol ssh show command displays the cluster-wide SSH configuration in advanced privilege mode. Use the security protocol ssh modify command to change the SSH configuration that the cluster supports.
The following example displays cluster-wide SSH configuration:
cluster1::*> security protocol ssh show
Per-Source Limit: 32
Maximum Number of Instances: 64
     Connections Per Second: 10
 PDFs
PDFs
