security protocol ssh show
PDF of this doc site
Creating your file...
Your file is ready
Show the SSH configuration
The security protocol ssh show
command displays the cluster-wide SSH configuration in advanced privilege mode. Use the security protocol ssh modify command to change the SSH configuration that the cluster supports.
The following example displays cluster-wide SSH configuration:
cluster1::*> security protocol ssh show Per-Source Limit: 32 Maximum Number of Instances: 64 Connections Per Second: 10
