      volume efficiency stop
Stop efficiency operation on a volume
Use the volume efficiency stop command to stop an efficiency operation.
-vserver <vserver name>- Vserver Name-
This specifies the Vserver on which the volume is located.
-volume <volume name>- Volume Name -
This specifies the name of the volume on which efficiency operation needs to be stopped.
-path </vol/volume>- Volume Path } -
This specifies the volume path on which efficiency operation needs to be stopped.
 [-a, -all <true>]- Stop All Operations-
This specifies both active and queued efficiency operations to be aborted.
The following examples stop efficiency on a volume.
cluster1::> volume efficiency stop -vserver vs1 -volume vol1
cluster1::> volume efficiency stop -vserver vs1 -volume vol1 -all
