      vserver services web access delete
Remove role authorization for web service access
This command removes the authorization of a role from the Vserver's web services. A service for which no roles are defined has a single role of 'none' automatically displayed in this configuration.
|  | Node Vserver services are authorized with the data Vserver's roles. |
- -vserver <Vserver Name>- Vserver
Identifies a Vserver for hosting a specific web service.
- -name <text>- Service Name
Identifies the name of the web service.
- -role <text>- Role Name
Identifies the role whose authorization is to be removed. You cannot remove the authorization of the role 'none'. Use vserver services web access create to authorize access for the role.
The following example removes authorization for the role auditor for the web service:
cluster1::> vserver services web access delete -name ontapi -role auditor
 PDFs
PDFs
