vserver cifs group-policy show
Show group policy configuration
The vserver cifs group-policy show command displays information about group policy configuration for CIFS-enabled Vserver. It displays all or a subset of the group policy configuration matching the criteria that you specify.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays group policy configuration only for the Vserver that you specify.
[-status {enabled|disabled}]- Group Policy Status-
If you specify this parameter, the command displays group policy configuration only for the Vservers that match the status you specify.
The following example displays group policy configuration for all Vservers:
cluster1::> vserver cifs group-policy show Vserver GPO Status -------------- ---------- vs1 disabled
