      system configuration recovery cluster show
Show cluster recovery status
The system configuration recovery cluster show command displays the cluster recovery status. Cluster recovery status is "not-in-recovery" under normal operations, and it becomes "in-progress" if a new cluster is created using the system configuration recovery cluster recreate command with the -from backup parameter. When cluster recovery status is "in-progress", wait until the output of the "Is Recovery Status Persisted" field is true before using the system configuration recovery cluster rejoin command to recover other nodes in the cluster.
The following example displays the cluster recovery status.
source::> system configuration recovery cluster show
              Recovery Status: in-progress
 Is Recovery Status Persisted: true
 PDFs
PDFs
