The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume move trigger-cutover
PDF of this doc site
Creating your file...
Your file is ready
Trigger cutover of a move job
This command causes a replicating or deferred volume move job to attempt cutover. Unless the force option is set, cutover entry is not guaranteed.
-vserver <vserver name>
- Vserver Name-
The Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
The volume that is being moved.
[-force <true>]
- Force Cutover-
If this parameter is specified, the cutover is done without confirming the operation - even if the operation could cause client I/O disruptions.
cluster1::> volume move trigger-cutover -vserver vs0 -volume testvol_1 -force
