ONTAP 9.10.1 commands
statistics settings show
Display settings for the statistics commands
This command displays the current settings for all of the statistics commands.
The following example displays the current settings for all statistics commands:
cluster1::*> statistics settings show
Display rate Counters in rate/sec: true
Counter Display: full
Counter Display Units: MB
Display Count Exponent: 3
