ONTAP 9.10.1 commands
system node external-cache show
Display external cache settings.
The system node external-cache show command displays external-cache information for each of the nodes available.
{ [-fields <fieldname>,…​]
Valid values for this option are {node|is-enabled|is-rewarm-enabled|is-mbuf-inserts-enabled|pcs-size|is-hya-enabled} . Specifying the value will display all entries that correspond to it.
| [-instance ] }
This option does not need an input value. Specifying this option will display the information about all the entries.
[-node {<nodename>|local}] - Node
Specify this parameter to display external-cache parameters that match the specified node.
[-is-enabled {true|false}] - Is Enabled?
Valid values for this option are true and false. Specifying the value will display all entries that correspond to it.
[-is-rewarm-enabled {true|false}] - Is Rewarm On?
[-is-mbuf-inserts-enabled {true|false}] - Is Mbuf Inserts On?
[-pcs-size <integer>] - PCS Size
Valid values for this option are integers between 16 and 16383. Specifying the value will display all entries that correspond to it.
[-is-hya-enabled {true|false}] - Is HyA Caching Enabled?
cluster1::> system node external-cache show -node node1
Node: node1
            Is Enabled: false
          Is rewarm on: false
    Is Mbuf inserts on: true
              PCS size: 256
Is hya caching enabled: true
Displays the external-cache information about node1 in a list format.
