ONTAP commands
vserver show
Display Vservers
The vserver show command displays the following information:
  • Vserver name
  • Vserver type (data , admin , node or system - detailed view only)
  • Vserver subtype (default , dp-destination , sync-source , and sync-destination - detailed view only)
  • Vserver universal unique identifier (detailed view only)
  • Root volume name
  • Aggregate on which the root volume is located
  • Associated NIS domain
  • Root volume security style (unix for UNIX mode bits, ntfs for CIFS ACLs, mixed for both (detailed view only)
  • LDAP client
  • Language (detailed view only)
  • Snapshot policy (detailed view only)
  • Comment text (detailed view only)
  • Quota policy (detailed view only)
  • Aggregate list (detailed view only)
  • Maximum Volumes (detailed view only)
  • Qos-policy-group (detailed view only)
  • Config-lock (detailed view only)
  • Admin state (running , stopped , starting , stopping , initializing , or deleting )
  • Operational state (running , or stopped )
  • Operational state stopped reason (sync-destination-and-switchover-not-done , or cluster-reboot-done , or admin-state-stopped )
  • Allowed Protocols (nfs , cifs , fcp , iscsi , nvme , ndmp - detailed view only)
  • Disallowed Protocols (nfs , cifs , fcp , iscsi , nvme , ndmp - detailed view only)
  • IPspace to which the Vserver belongs (detailed view only)
  • Caching policy
{ [-fields <fieldname>,…​]
| [-protocols ]
If this optional parameter is specified, the command displays the allowed and disallowed set of protocols for the Vserver(s).
| [-instance ] }
[-vserver <vserver>] - Vserver
If this parameter is specified, the command displays detailed information about the specified Vserver.
[-type <vserver type>] - Vserver Type
If this parameter is specified, the command displays information only about the Vserver or Vservers that have the specified Vserver type. Types include admin for the cluster-wide management Vserver, system for cluster-level communications in an IPspace, data for data serving Vserver, and node for node management Vserver.
[-subtype <vserver subtype>] - Vserver Subtype
If this parameter is specified, the command displays information only about the Vserver or Vservers that have the specified Vserver subtype. Types include:
  • default for default data Vserver
    and
  • dp-destination for Data Protection destination Vserver.
  • sync-source for MetroCluster source Vserver,
  • sync-destination for MetroCluster destination Vserver.
[-uuid <UUID>] - Vserver UUID
If this parameter is specified, the command displays information only about the Vserver that match the specified UUID.
[-rootvolume <volume name>] - Root Volume
If this parameter is specified, the command displays information only about the Vserver or Vservers that have the specified root volume.
[-aggregate <aggregate name>] - Aggregate
If this parameter is specified, the command displays information only about the Vserver or Vservers that have their root volumes contained by the specified aggregate.
[-nisdomain <nis domain>] - NIS Domain
If this parameter is specified, the command displays information only about the Vserver or Vservers that use the specified NIS domain.
[-rootvolume-security-style <security style>] - Root Volume Security Style
If this parameter is specified, the command displays information only about the Vserver or Vservers that have the specified root-volume security style.
[-ldap-client <text>] - LDAP Client
If this parameter is specified, the command displays information only about the Vserver or Vservers that use the specified LDAP client.
[-language <Language code>] - Default Volume Language Code
If this parameter is specified, the command displays information only about the Vserver or Vservers that use the specified language. To determine the available languages, enter "`vserver show-language?` " at the clustershell command prompt and at the Vserver prompt.
[-snapshot-policy <snapshot policy>] - Snapshot Policy
If this parameter is specified, the command displays information only about the Vserver or Vservers that have the specified Snapshot policy.
[-data-services <LIF Service Name>,…​] - Data Services
If this parameter is specified, the command displays information only about the Vserver or Vservers that match the specified data services.
[-comment <text>] - Comment
If this parameter is specified, the command displays information only about the Vserver or Vservers that match the specified comment.
[-quota-policy <text>] - Quota Policy
If this parameter is specified, the command displays information only about the Vserver or Vservers that use the specified quota policy.
[-aggr-list <aggregate name>,…​] - List of Aggregates Assigned
If this parameter is specified, the command displays information only about the Vserver or Vservers to which the specified aggregate(s) are assigned for use.
[-max-volumes <unsigned32_or_unlimited>] - Limit on Maximum Number of Volumes allowed
If this parameter is specified, the command displays information only about the Vserver or Vservers on which the specified maximum volume count is configured.
[-admin-state {running|stopped|starting|stopping}] - Vserver Admin State
If this parameter is specified, the command displays information only about the Vserver or Vservers that match the specified admin-state.
[-operational-state {running|stopped}] - Vserver Operational State
If this parameter is specified, the command displays information only about the Vserver or Vservers that match the specified operational-state. This field determines the state of the Vserver LIFs. New LIFs created on a Vserver, which is in running state, will be operationally up and the LIFs created on a Vserver, which is in stopped state, will be operationally down.
[-operational-state-stopped-reason {sync destination and switchover is not done|cluster reboot is done|admin state stopped| dp destination not started}] - Vserver Operational State Stopped Reason
If this parameter is specified, the command displays information only about the Vserver or Vservers that are operationally stopped due to the specified reason. This field indicates the reason for the operational-state of the Vserver being stopped
[-allowed-protocols {nfs|cifs|fcp|iscsi|ndmp|nvme}] - Allowed Protocols
If this parameter is specified, the command displays information only about the Vserver or Vservers on which the specified protocols are allowed to run.
[-disallowed-protocols {nfs|cifs|fcp|iscsi|ndmp|nvme}] - Disallowed Protocols
If this parameter is specified, the command displays information only about the Vserver or Vservers on which the specified protocols are disallowed to run.
[-is-repository {true|false}] - Is Vserver with Infinite Volume
If this parameter is no longer supported.
[-qos-policy-group <text>] - QoS Policy Group
Display the Vservers that match the specified qos-policy-group.
A policy group defines measurable service level objectives (SLOs) that apply to the storage objects with which the policy group is associated. If you do not assign a policy group to a Vserver, the system will not monitor and control the traffic to it.
[-caching-policy <text>] - Caching Policy Name
Display the Vservers that match the specified caching-policy.
A caching policy defines the caching behavior of this Vserver at the Flash Cache level. If a caching policy is not assigned to this Vserver, the system uses the default cluster-wide policy. The available caching policies are:
  • none - Does not cache any user data or metadata blocks.
  • auto - Read caches all metadata and randomly read user data blocks, and write caches all randomly overwritten user data blocks.
  • meta - Read caches only metadata blocks.
  • random_read - Read caches all metadata and randomly read user data blocks.
  • random_read_write - Read caches all metadata, randomly read, and randomly written user data blocks.
  • all_read - Read caches all metadata, randomly read, and sequentially read user data blocks.
  • all_read_random_write - Read caches all metadata, randomly read, sequentially read, and randomly written user data.
  • all - Read caches all data blocks read and written. It does not do any write caching.
Default caching-policy is auto.
[-config-lock {true|false}] - Config Lock
This parameter specifies if the Vserver is locked or unlocked for modification. If the config-lock is set to true, then modifying the Vserver's configuration is not allowed.
[-ipspace <IPspace>] - IPspace Name
If this parameter is specified, the command displays information only about the Vservers that are assigned to the specified IPspace.
[-foreground {true|false}] - Foreground Process
This optionally specifies whether the Vserver show operation can be executed in the background. If nothing is specified, by default the Vserver show operation is executed in the foreground.
[-is-space-reporting-logical {true|false}] - Logical Space Reporting
This optionally specifies whether to report space logically on residing volumes. When space is reported logically, ONTAP reports the volume space such that all the physical space saved by the storage efficiency features are also as reported as used.
[-is-space-enforcement-logical {true|false}] - Logical Space Enforcement
This optionally specifies whether to perform logical space accounting on residing volumes. When space is enforced logically, ONTAP enforces volume settings such that all the physical space saved by the storage efficiency features will be calculated as used.
[-anti-ransomware-default-volume-state {disabled|dry-run}] - Default Anti_ransomware State of the Vserver's Volumes
This optionally specifies the default anti_ransomware state for the volumes in the Vserver. The available anti_ransomware states for the volumes in the Vserver are:
  • disabled - Anti_ransomware protection is not enabled on the volumes in the Vserver.
  • dry-run - Anti_ransomware protection is in evaluation mode on the volumes in the Vserver.
The following example displays information about all Vservers.
cluster1::> vserver show
non mcc setup:
                  Admin    Operational   Root
Vserver      Type    Subtype        state    state      Volume  Aggregate
cluster      admin   -          -    -           -    -
node1      node    -          -    -           -    -
vs0        data    default        running  running      root_vs1  aggr0
vs1        data    dp-destination   stopped  stopped      -    -
4 entries were displayed.
mcc setup:
vs2           data    sync-source    running  running   rv         data_aggr
vs3-mc      data    sync-destination  running  stopped  -      -
Looking for answers?
Try Doc, our Gen AI Assistant.
