      system ha interconnect ood send-diagnostic-buffer
Send diagnostic buffer to partner
The system ha interconnect ood send-diagnostic-buffer command enables you to run a short out-of-order delivery diagnostic test. The command sends a buffer to the partner controller over the high-availability interconnect. This command is only supported on FAS2500 series nodes in the cluster.
- -node <nodename>- Node (privilege: advanced)
This mandatory parameter specifies which node will send the diagnostic buffer to its partner. The value "local" specifies the current node.
The following example demonstrates how to use this command to send a diagnostic buffer to the partner:
cluster1::*> system ha interconnect ood send-diagnostic-buffer -node ic-f2554-03
 PDFs
PDFs
