ONTAP 9.10.1 commands
vserver vscan scanner-pool privileged-users remove
Remove from the list of privileged users
The vserver vscan scanner-pool privileged-users remove command removes one privileged users or list of privileged users from the specified scanner pool. All the existing privileged users of a scanner pool cannot be removed.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver containing the specified scanner pool on which you want to remove a privileged user or users.
-scanner-pool <Scanner pool> - Scanner Pool
This parameter specifies the name of the scanner pool from which you want to remove a privileged user or users.
-privileged-users <Privileged user>,…​ - List of Privileged Users
This parameter specifies the privileged user or users that you want to remove from the specified scanner pool.
The following example removes a list of privileged users from the specified scanner pool.
cluster1::> vserver vscan scanner-pool privileged-users remove -vserver vs1
            -scanner-pool p1 -privileged-users cifs\u2,cifs\u3
cluster1::> vserver vscan scanner-pool privileged-users show -vserver vs1
            -scanner-pool p1
Vserver: vs1
            Scanner Pool: p1
List of Privileged Users: cifs\u1
