system snmp show
Displays SNMP settings
Lists the current values of all the SNMP parameters.
The example below shows a typical command display.
cluster1::> system snmp show contact: private location: NB authtrap: 1 init: 1 traphosts: xxx.example.com(xxx.example.com)(192.168.xxx.xxx) community: - -
