security session limit vserver show
Show per-vserver session limits
This command shows the per-Vserver management session limits that have been configured for each interface and Vserver.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-interface {cli|ontapi|rest}]- Interface (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the interface (CLI, ONTAPI, or REST) to which the limit applies.
- [-vserver <vserver>]- Vserver (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the Vserver for the limit. The "Cluster" Vserver is used to limit Vservers that do not have a configured limit.
- [-max-active-limit <integer>]- Max-Active Limit (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the configured limit that is used to throttle or reject requests.
The following example illustrates displaying the per-Vserver limits for management sessions.
cluster1::*> security session limit vserver show Interface Vserver Max-Active --------- -------------------- ---------- cli Cluster 4 ontapi Cluster 2 ontapi cluster1 16 3 entries were displayed.
 PDFs
PDFs
