security session limit vserver show
Show per-vserver session limits
This command shows the per-Vserver management session limits that have been configured for each interface and Vserver.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-interface {cli|ontapi|rest}]- Interface (privilege: advanced)-
Selects the sessions that match this parameter value. This identifies the interface (CLI, ONTAPI, or REST) to which the limit applies.
[-vserver <vserver>]- Vserver (privilege: advanced)-
Selects the sessions that match this parameter value. This identifies the Vserver for the limit. The "Cluster" Vserver is used to limit Vservers that do not have a configured limit.
[-max-active-limit <integer>]- Max-Active Limit (privilege: advanced)-
Selects the sessions that match this parameter value. This identifies the configured limit that is used to throttle or reject requests.
The following example illustrates displaying the per-Vserver limits for management sessions.
cluster1::*> security session limit vserver show Interface Vserver Max-Active --------- -------------------- ---------- cli Cluster 4 ontapi Cluster 2 ontapi cluster1 16 3 entries were displayed.
