storage aggregate plex show
Show plex details
The storage aggregate plex show command displays information for the specified plex. By default, the command displays the following information about all plexes:
Aggregate Name
Plex Name
Is Online
Is Resyncing
Resyncing Percentage
Plex Status
To display detailed information about a single plex, use the -aggregate and -plex parameter.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-aggregate <aggregate name>]- Aggregate-
Name of an existing aggregate which contains the plex specified with the
-plexparameter. [-plex <text>]- Plex Name-
Name of a plex which belongs to the aggregate specified with the
-aggregateparameter. [-status <text>]- Status-
Displays plex status. Possible values are:
normal -
failed -
empty -
invalid -
uninitialized -
failed assimilation -
limbo -
active -
inactive -
resyncing
These values may appear by themselves or in combination separated by commas, for example, "
normal,active". -
[-is-online {true|false}]- Is Online-
Selects the plexes that match this parameter value.
[-in-progress {true|false}]- Resync is in Progress-
[-resyncing-percent <percent>]- Resyncing Percentage-
[-resync-level <integer>]- Resync Level-
[-pool <integer>]- Pool-
The following example displays information about all the plexes for all the aggregates:
cluster1::> storage aggregate plex show
Is Is Resyncing
Aggregate Plex Online Resyncing Percent Status
aggr0 plex0 true false - normal,active
aggr1 plex0 true false - normal,active
aggr1 plex1 true false - normal,active
aggr2 plex0 true false - normal,active
aggr2 plex2 true false - normal,active
5 entries were displayed.
The following example displays information about plex1 of aggregate aggr1:
cluster1::> storage aggregate plex show -aggregate aggr1 -plex plex1
Aggregate: aggr1
Plex Name: plex1
Status: normal,active
Is Online: true
Resync is in Progress: false
Resyncing Percentage: -
Resync Level: -
Pool: 1
