storage tape config-file show
PDF of this doc site
Creating your file...
Display the list of tape drive configuration files on the given node
The storage tape config-file show
command lists the tape drive configuration files loaded onto each node in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects information about tape drive configuration files for the specified node.
[-config-file <text>]
- Tape Config File-
Selects information about the tape drive configuration file specified.
The following example lists the tape drive config files loaded onto each node in the cluster:
cluster1::> storage tape config-file show Node: node1 Tape Config Files ---------------------------------------- CERTANCE_LTO2_ULTRIUM.TCF CERTANCE_LTO3_ULTRIUM.TCF HP_LT09.TCF HP_LTO2.TCF HP_LTO3_ULTRIUM.TCF HP_LTO4_ULTRIUM.TCF HP_LTO5_ULTRIUM.TCF HP_LTO6_ULTRIUM.TCF IBM_3592.TCF IBM_3592E05.TCF IBM_5038_sdfkjl.TCF IBM_LTO2_ULT3580.TCF IBM_LTO2_ULTRIUM.TCF
