ONTAP commands
storage port show
Show storage port information
The storage port show command displays information about the storage ports in the cluster. If no parameters are specified, the default command displays the following information about the storage ports:
  • Node
  • Port
  • Type
  • Speed
  • State
  • Status
To display detailed profile information about a single storage port, use the -node and -port parameters.
{ [-fields <fieldname>,…​]
Displays the specified fields for all the storage ports, in column style output.
| [-errors ]
Displays the following error status information about the storage ports which have errors:
  • Error type
  • Error severity
  • Error description
| [-instance ] }
Displays expanded information about all the storage ports in the system. If a storage port is specified, then this parameter displays detailed information for that port only.
[-node {<nodename>|local}] - Node
Displays detailed information about the storage ports on the specified node.
[-port <text>] - Port
Selects the ports with the specified port name.
[-port-type {Unknown|SAS|FC}] - Port Type
Selects the ports of the specified type.
[-port-speed {0|1|1.5|2|3|4|6|8|10|12|16|32}] - Port Speed
Selects the ports with the specified speed.
[-state {enabled|disabled}] - Port State
Selects the ports with the specified state.
[-status {unknown|online|online-degraded|offline|link-down}] - Port Status
Selects the ports with the specified operational status.
[-description <text>] - Description
Selects the ports with the specified description.
[-firmware-rev <text>] - Firmware Revision
Selects the ports with the specified firmware revision.
[-serial-number <text>] - Serial Number
Selects the ports with the specified serial number.
[-connection-mode {Unknown|Loop|Point-to-point}] - Connection Mode
Selects the ports with the specified connection mode.
[-wwnn <FC WWN>] - World Wide Node Name
Selects the ports with the specified World Wide Node Name.
[-wwpn <FC WWN>] - World Wide Port Name
Selects the ports with the specified World Wide Port Name.
[-board-name <text>] - Board Name
Selects the ports with the specified board name.
[-connector-capabilities <integer>,…​] - Connector Capabilities
Selects the ports with the specified list of connector capabilities.
[-wwn <FC WWN>] - Base World Wide Name
Selects the ports with the specified World Wide Name.
[-mfg-part-number <text>] - MFG Part Number
Selects the ports with the specified manufacturer part number.
[-nvdata-rev <text>] - NVDATA Revision
Selects the ports with the specified NVDATA revision.
[-part-number <text>] - Part Number
Selects the ports with the specified part number.
[-date-code <text>] - Date Code
Selects the ports with the specified date code.
[-cable-length <text>] - Cable Length
Selects the ports with the specified cable length.
[-cable-identifier <text>] - Cable Identifier
Selects the ports with the specified cable identifier.
[-cable-end-id {end_0|end_1}] - Cable End Identifier
Selects the ports with the specified cable end identifier.
[-connector-technology {active-copper|passive-copper|optical}] - Connector Technology
Selects the ports with the specified connector technology.
[-phy-id <integer>,…​] - Phy ID
Selects the ports that have phys with the specified phy ID.
[-phy-state {enabled|disabled}] - Phy State
Selects the ports that have phys with the specified state.
[-phy-status {unknown|online|offline|speed-negotiation-failed|sata-oob-failed}] - Phy Status
Selects the ports that have phys with the specified status.
[-phy-speed {0|1|1.5|2|3|4|6|8|10|12|16|32}] - Phy Speed
Selects the ports that have phys with the specified speed.
[-error-type {unknown|online|online-degraded|offline|link-down}] - Error Type
Selects the ports with the specified error type.
[-error-severity {unknown|notice|warning|error|critical}] - Error Severity
Selects the ports with the specified error severity.
[-error-text <text>] - Error Text
Selects the ports with the specified error text.
[-corrective-action <text>] - Corrective Action
Selects the ports with the specified corrective action.
[-connector-type {QSFP|QSFP+|Mini-SAS HD|SFP}] - Connector Type
Selects the ports with the specified connector type.
[-connector-vendor <text>] - Connector Vendor
Selects the ports with the specified connector vendor.
[-connector-part-number <text>] - Connector Part Number
Selects the ports with the specified connector part number.
[-connector-serial-number <text>] - Connector Serial Number
Selects the ports with the specified connector serial number.
The following example displays information about all storage ports in the cluster:
cluster1::> storage port show
Speed
Node               Port Type (Gb/s) State    Status
node1
                   0a   SAS       0 disabled offline
                   0b   SAS       6 enabled  online
                   1a   FC        0 disabled offline
                   1b   FC        2 enabled  online
node2
                   0a   SAS       6 enabled  online
                   0b   SAS       6 enabled  online-degraded
                   1a   FC        2 enabled  online
The following example displays detailed information about port 0a on node node1:
cluster1::> storage port show -node node1 -port 0b
Node: node1
                   Port: 0b
            Description: SAS Host Adapter 0b (PMC-Sierra PM8001 rev. C)
      Firmware Revision: 01.12.06.00
               Base WWN: 50:0a:09:80:00:82:47:b4
         Connector Type: qsfp
       Connector Vendor: Molex Inc.
  Connector Part Number: 112-00177+A0
   Connector Technology: passive_copper
Connector Serial Number: 017920547
           Cable Length: 2m
   Cable End Identifier: end_1
       Cable Identifier: 500a09800082847f-500a0980008247b4
             Port Speed: 6 Gb/s
             Port State: enabled
            Port Status: online
              Phy State: [0]  enabled,  online,  6 Gb/s
                         [1]  enabled,  online,  6 Gb/s
                         [2]  enabled,  online,  6 Gb/s
                         [3]  enabled,  online,  6 Gb/s
