vserver data-policy validate
Validate a data policy without import
The vserver data-policy validate command checks a data policy for errors, without modifying the data policy for the Vserver with Infinite Volume.
-vserver <vserver name>- Vserver Name-
This specifies the Vserver with Infinite Volume for which the data policy will be validated.
The following examples show first a problem with a given data policy, and then an example of a valid data policy.
cluster1::> vserver data-policy validate -vserver vs1
Enter the contents of the file data policy for Vserver "vs1":
Press <Enter> when done
{ "foo" : "bar" }
Error: command failed: Data Policy validation failed: 'ruleset_format_version'
is a required field.
{ "ruleset_format_version" : "1.0",
"rules" : [
{ "rule_label" : "default",
"rule_id" : "ec17a05f-7785-11e1-baf4-123478563412",
"rule_scope" : [],
"rule_epoch" : { "epoch_reference" : "ctime" },
"rule_epochs" : {
"0" : {
"local" : {
"metadata" : {
"storageservice" : "-"
Data Policy validation succeeded: No errors found.
