vserver security trace filter show
Display a security trace entry
The vserver security trace filter show command displays information about security trace filter entries. Prior to Data ONTAP 9.3, this feature was only supported for CIFS. In Data ONTAP 9.3 and later, this feature is supported for both NFS and CIFS.
The vserver security trace filter show command is not supported for Vservers with Infinite Volume.
NFS security trace filters are not supported for FlexGroup volumes, and will only be applied to the FlexVol volumes within the specified Vserver.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified Vserver.
[-index <integer>]- Filter Index-
If you specify this parameter, the command displays permission tracing information only for filters with the specified filter index number.
[-protocols {cifs|nfs}]- Protocols-
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified protocols.
[-client-ip <IP Address>]- Client IP Address to Match-
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified client IP address.
[-path <TextNoCase>]- Path-
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified path.
[-windows-name <TextNoCase>]- Windows User Name-
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified Windows user name.
[-unix-name <TextNoCase>]- UNIX User Name or User ID-
If you specify this parameter, the command displays permission tracing information only for filters applied to the specified UNIX user name or user ID(for NFS specififc filters).
[-trace-allow {yes|no}]- Trace Allow Events-
If you specify this parameter, the command displays information only about events that either trace or do not trace allow events, depending on the value provided.
[-enabled {enabled|disabled}]- Filter Enabled-
If you specify this parameter, the command displays information only about filters that either are enabled or disabled, depending on the value provided.
[-time-enabled <integer>]- Minutes Filter is Enabled-
If you specify this parameter, the command displays information only about filters that are disabled after the specified minutes.
The following example displays security trace filters for Vserver vserver1 .
cluster1::> vserver security trace filter show
Vserver Index Client-IP Path Trace-Allow Windows-Name Protocol
vserver1 1 - - no domain\user cifs
vserver1 2 192.168.2.3 - yes - cifs
vserver1 3 - /dir1/dir2/file no domain\ cifs
administrator
vserver1 4 - file yes - nfs
4 entries were displayed.
