vserver group-mapping show
Display group mappings
The vserver group-mapping show command displays information about group mappings. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all group mappings:
Vserver name
Direction of the mapping (krb-unix for Kerberos-to-UNIX, win-unix for Windows-to-UNIX, or unix-win for UNIX-to-Windows)
Position of the mapping in the priority list
Pattern to be matched
Replacement pattern
You can specify additional parameters to display only information that matches those parameters. For instance, to display information only about Kerberos-to-UNIX group mappings, run the command with the -direction krb-unix parameter.
The vserver group-mapping show command is not supported on Vservers with FlexVol volumes.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about the group mapping or mappings that match the specified Vserver.
[-direction {krb-unix|win-unix|unix-win}]- Name Mapping Direction-
If you specify this parameter, the command displays information only about the group mapping or mappings that have the specified mapping direction.
[-position <integer>]- Position-
If you specify this parameter, the command displays information only about the group mapping that has the specified position in the priority list.
[-pattern <text>]- Pattern-
If you specify this parameter, the command displays information only about the group mapping or mappings that use the specified matching pattern. The pattern can be up to 256 characters in length. Refer to the command description section for details.
[-replacement <text>]- Replacement-
If you specify this parameter, the command displays information only about the group mapping or mappings that use the specified replacement pattern.
The following example displays information about all group mappings:
cluster1::> vserver group-mapping show
Vserver Direction Position
vs1 win-unix 1 Pattern: EXAMPLE\\artists
Replacement: nobody
vs1 unix-win 1 Pattern: EXAMPLE\\(.+)
Replacement: \_1
vs2 win-unix 1 Pattern: (.+)
Replacement: EXAMPLE\\artists
