ONTAP 9.3 commands
job pause
Pause a job
The job pause command pauses a job. Use the job resume command to resume a paused job. Use the job show command to view a list of running jobs that can be paused.
-id <integer> - Job ID
The numeric ID of the job you want to pause. A job ID is a positive integer.
[-vserver <vserver name>] - Owning Vserver
Use this parameter to specify the name of the Vserver that owns the job.
The following example pauses the job that has ID 183:
cluster1::> job pause -id 183
