volume snaplock modify
Modify SnapLock attributes of a SnapLock volume
The ` volume snaplock modify ` command modifies one or more SnapLock attributes of a SnapLock volume.
-vserver <vserver name>- Vserver-
This specifies the vserver which owns the required SnapLock volume.
-volume <volume name>- Volume-
This specifies the SnapLock volume whose attribute needs to be modified.
[-minimum-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]- Minimum Retention Period -
Specifies the minimum allowed retention period for files committed to WORM state on the volume. Any files committed with a retention period shorter than this minimum value, is assigned this minimum value.
If this option value is
infinite, then every file committed to the volume will have a retention period that never expires.Otherwise, the retention period is specified as a number followed by a suffix. The valid suffixes are seconds, minutes, hours, days, months, and years. For example, a value of 6months represents a retention period of 6 months. The maximum allowed retention period is 70 years. This option is not applicable while extending retention period of an already committed WORM file.
[-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | min | max | infinite}]- Default Retention Period-
Specifies the default retention period that is applied to files while committing to WORM state without an associated retention period.
min, then minimum-retention-period is used as the default retention period. If this option value ismax, then maximum-retention-period is used as the default retention period. If this option value isinfinite, then a retention period that never expires will be used as the default retention period.The retention period can also be explicitly specified as a number followed by a suffix. The valid suffixes are seconds, minutes, hours, days, months, and years. For example, a value of 6months represents a retention period of 6 months. The maximum valid retention period is 70 years.
[-maximum-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]- Maximum Retention Period-
Specifies the maximum allowed retention period for files committed to WORM state on the volume. Any files committed with a retention period longer than this maximum value, is assigned this maximum value.
infinite, then files that have retention period that never expires might be committed to the volume.Otherwise, the retention period is specified as a number followed by a suffix. The valid suffixes are seconds, minutes, hours, days, months, and years. For example, a value of 6months represents a retention period of 6 months. The maximum allowed retention period is 70 years. This option is not applicable while extending retention period of an already committed WORM file.
[-autocommit-period {{<integer> hours|days} | none}]- Autocommit Period-
Specifies the autocommit period for SnapLock volume. All files which are not modified for a period greater the autocommit period of the volume are committed to WORM state.
The autocommit period option is specified as a number followed by a suffix. The valid suffixes for autocommit period are days and hours. For example, a value of 2hours represents an autocommit period of 2 hours. The minimum allowed autocommit period is 2 hours and the maximum allowed autocommit period is 7 days.
none, then autocommit is disabled on the SnapLock volume. [-is-volume-append-mode-enabled {true|false}]- Is Volume Append Mode Enabled-
Specifies if the volume append mode is enabled or disabled.
It can be modified only when the volume is not mounted and does not have any data or Snapshot copies.
The volume append mode is not supported on SnapLock audit log volumes.
When it is enabled, all the files created with write permissions on the volume are WORM appendable files by default. All the WORM appendable files that are not modified for a period greater than the autocommit period of the volume are also committed to the WORM read-only state.
If it is set to
true, then the volume append mode is enabled.If it is set to
false, then the volume append mode is disabled.Volume append mode is disabled by default when the volume is created.
[-privileged-delete {disabled|enabled|permanently-disabled}]- Privileged Delete } -
Specifies the privileged-delete attribute of a SnapLock volume. This parameter must be specified alone.
If it is set to
enabledthen the privileged-delete operation can be performed using the volume file privileged-delete command.If it is set to
disabled, then the privileged-delete operation is not supported.Once it is set to
permanently-disabled, then neither the privileged-delete operation nor any change in the volume privileged-delete attribute is permitted.
The following command sets -default-retention-period of a given SnapLock volume:
cluster1::> volume snaplock modify -volume vol_slc -default-retention-period 2years cluster1::>
The following command sets -maximum-retention-period of a given SnapLock volume to infinite :
cluster1::> volume snaplock modify -volume vol_slc -maximum-retention-period infinite cluster1::>
The following command enables the privileged-delete operation on a SnapLock volume.
cluster1::> volume snaplock modify -vserver vs1 -volume vol_sle -privileged-delete enabled [Job 38] Job succeeded: Privileged-delete Attribute Change for Volume "vs1:vol_sle" Completed. cluster1::> cluster1::>volume snaplock show -vserver vs1 -volume vol_sle -fields privileged-delete vserver volume privileged-delete ------- -------- ----------------- vs1 vol_sle enabled cluster1::>
