security session limit vserver modify
Modify per-vserver session limit
This command allows modification of a per-Vserver management session limit.
-interface {cli|ontapi}- Interface (privilege: advanced)-
The interface (CLI or ONTAPI) to which the limit applies.
-vserver <vserver>- Vserver (privilege: advanced)-
The specified Vserver to which this limit applies. The "Cluster" Vserver is used to limit Vservers that do not have a configured limit.
[-max-active-limit <integer>]- Max-Active Limit (privilege: advanced)-
The maximum number of concurrent sessions allowed for this interface and Vserver.
The following example illustrates modifying the admin Vserver's limit for CLI management sessions.
cluster1::*> security session limit vserver modify -interface cli -vserver cluster1 -max-active-limit 40
