vserver fcp wwpn-alias set
Set an alias for a World Wide Port Name of an initiator that might login to the target.
This command creates a new alias for a World Wide Port Name (WWPN). You can create multiple aliases for a WWPN, but you cannot use the same alias for multiple WWPNs.
An alias name is a case-sensitive name that must contain one to 32 characters. Spaces are not allowed.
- -vserver <Vserver Name>- Vserver Name
Specifies the Vserver.
- -a, -alias <text>- Initiator WWPN Alias
Specifies the alias of the WWPN.
- -w, -wwpn <FC WWN>- Initiator WWPN
Specifies the WWPN.
- [-f, -force <true>]- Force
Allows you to override a WWPN associated with an existing alias with a newly specified WWPN. If you use this parameter without a value, it is set to true, and the command does not prompt you when you override an existing alias.
cluster1::> vserver fcp wwpn-alias set -vserver vs_1 -alias my_alias -wwpn 2f:a0:00:a0:98:0b:56:13
Sets the alias my_alias for the WWPN 2f:a0:00:a0:98:0b:56:13 .
 PDFs
PDFs
