volume file clone split load show
Show split load on a node
The volume file clone split load show command displays the corresponding file or LUN clone split loads on nodes.If no parameters are specified, the command displays the following information:
Node
Max Split Load
Current Split Load
Token Reserved Load
Allowable Split Load
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name-
Node on which the file or LUN Clone split load is displayed.
[-max-split-load {<integer>[KB|MB|GB|TB|PB]}]- Maximum Clone Split Load-
This specifies the maximum allowable split load on the node.
[-current-split-load {<integer>[KB|MB|GB|TB|PB]}]- Current Clone Split Load-
This specifies the current on going split load on the node.
[-token-reserved-load {<integer>[KB|MB|GB|TB|PB]}]- Load Reserved for Clone Creation-
This specifies the reserved split load of the node using the tokens.
[-allowable-split-load {<integer>[KB|MB|GB|TB|PB]}]- Allowable Clone Split Load-
This specifies the available split load of the node.
The following example displays the current and allowable file or LUN clone split load on a node.
cluster1::> volume file clone split load show
Node Max Current Token Allowable
Split Load Split Load Reserved Load Split Load
clone-01 15.97TB 0B 100MB 15.97TB
clone-02 15.97TB 0B 100MB 15.97TB
2 entries were displayed.
cluster1::> volume file clone split load show -node clone-01 -instance
Node Name: clone-01
Maximum Clone Split Load: 15.97TB
Current Clone Split Load: 0B
Load Reserved for Clone Creation: 100MB
Allowable Clone Split Load: 15.97TB
