application volume remove
Remove a volume from an application
This command removes a volume from an application. If the volume is the only member volume of an application component, the application component is deleted. If there are no more application components in the application, the application is deleted.
This command is provided to support downgrade and revert of Data ONTAP to versions prior to the support of applications. It should not be used for any other purpose. |
-vserver <vserver name>- Vserver (privilege: advanced)-
The Vserver of the volume to remove from the application.
-application <text>- Application (privilege: advanced)-
The name of the application from which to remove the volume.
-volume <volume name>- Volume (privilege: advanced)-
The volume to remove from the application.
cluster1::*> application volume remove -vserver vs1 -application app1 -volume vol1
The example above removes volume vol1 in Vserver vs1 from application app1. If this is the only volume in the application, the application is deleted.
