storage aggregate reallocation restart
Restart reallocate job on aggregate
Starts a reallocation job. Use this command to restart a quiesced (temporarily stopped) job or a scheduled scan that is idle for the aggregate.
-aggregate <aggregate name> - Aggregate Name
Specifies the aggregate on which you want to restart reallocation scans.
[-i, -ignore-checkpoint <true>] - Ignore Checkpoint
Restarts the job at the beginning when set to true. If you use this command without specifying this parameter, its effective value is false and the job starts the scan at the point where it was stopped. If you specify this parameter without a value, it is set to true and the scan restarts at the beginning.
cluster1::> storage aggregate reallocation restart
    -aggregate aggr0 -ignore-checkpoint true
Restarts reallocation job on aggregate aggr0 from the beginning.
