system services ndmp status
Display list of NDMP sessions
The system services ndmp status command lists all the NDMP sessions in the cluster. By default it lists the following details about the active sessions:
Node
Session ID
A combination of parameters can be optionally supplied so as to list only those sessions which match specific conditions. A short description of each of the parameter is provided in the parameters section. This command is not supported on Infinite Volumes.
[-fields <fieldname>,…] -
This optional parameter specifies which all additional fields to display. Any combination of the following fields are valid:
ndmp-version
session-authorized
data-state
data-operation
data-halt-reason
data-con-addr-type
data-con-addr
data-con-port
data-bytes-processed
mover-state
mover-mode
mover-pause-reason
mover-halt-reason
mover-record-size
mover-record-num
mover-bytes-moved
mover-seek-position
mover-bytes-left-to-read
mover-window-offset
mover-window-length
mover-position
mover-setrecordsize-flag
mover-setwindow-flag
mover-con-addr-type
mover-con-addr
mover-con-port
eff-host
client-addr
client-port
spt-device-id
spt-ha
spt-scsi-id
spt-scsi-lun
tape-device
tape-modes
is-secure-control-connection
data-backup-mode
data-path
source-addr
[-instance ]} -
If this parameter is specified, the command displays detailed information about all the active sessions.
[-node {<nodename>|local}]- Node-
If this parameter is specified, the command displays information about the sessions running on the specified node only. Node should be a valid node name.
[-session-id <integer>]- Session Identifier-
If this parameter is specified, the command displays information about specific NDMP session. A session-id is a number used to identify a particular NDMP session.
[-ndmp-version <integer>]- NDMP Version-
This parameter refers to the NDMP protocol version being used in the session.
[-session-authorized {true|false}]- Session Authorized-
This field indicates whether an NDMP session is authenticated or not.
[-data-state <component state>]- Data State-
This field identifies the current state of the data server's state machine.
[-data-operation <data operation>]- Data Operation-
This field identifies the data server's current operation.
[-data-halt-reason <halt reason>]- Data Server Halt Reason-
This field identifies the event that caused the data server state machine to enter the HALTED state.
[-data-con-addr-type <address type>]- Data Server Connect Type-
This field specifies the type of data connection established by the data server. The data connection can be established locally within a given system or between remote networked systems.
[-data-con-addr <text>]- Data Server Connect Address-
This specifies the connection endpoint information for the data server's data connection.
[-data-con-port <integer>]- Data Server Connect Port-
This specifies the TCP/IP port that the data server will use when establishing a data connection.
[-data-bytes-processed <integer>]- Data Bytes Processed-
This field represents the cumulative number of data stream bytes transferred between the backup or recovery method and the data connection during the current data operation.
[-mover-state <component state>]- Mover State-
This parameter identifies the current state of the NDMP tape server's mover state machine.
[-mover-mode <mover mode>]- Mover Mode-
This parameter identifies the direction of the mover data transfer.
[-mover-pause-reason <pause reason>]- Mover Pause Reason-
This parameter identifies the event that caused the mover state machine to enter the PAUSED state.
[-mover-halt-reason <halt reason>]- Mover Halt Reason-
This integer field identifies the event that caused the mover state machine to enter the HALTED state.
[-mover-record-size <integer>]- Mover Record Size-
This field represents the current mover record size in bytes.
[-mover-record-num <integer>]- Mover Record Number-
This field represents the last tape record processed by the mover.
[-mover-bytes-moved <integer>]- Mover Bytes Moved-
This field represents the cumulative number of data stream bytes written to the data connection or the number of data stream bytes read from the data connection and written to the tape subsystem, depending on the mode of mover operation.
[-mover-seek-position <integer>]- Mover Seek Position-
This field represents the data stream offset of the first byte the DMA requested the mover to transfer to the data connection during a mover read operation.
[-mover-bytes-left-to-read <integer>]- Mover Bytes Left to Read-
This field represents the number of data bytes remaining to be transferred to the data connection to satisfy the current NDMP_MOVER_READ request.
[-mover-window-offset <integer>]- Mover Window Offset-
This field represents the absolute offset of the first byte of the mover window within the overall data stream.
[-mover-window-length <integer>]- Mover Window Length-
This field represents the length of the current mover window in bytes.
[-mover-position <integer>]- Mover Position-
This parameter can be used to list only those sessions, whose mover position matches a specific value. Mover-position should be an integer.
[-mover-setrecordsize-flag {true|false}]- Mover SetRecordSize Flag-
This field is used by the DMA to establish the record size used for mover-initiated tape read and write operations.
[-mover-setwindow-flag {true|false}]- Mover SetWindow Flag-
This flag represents whether a mover window has been set or not. A mover window represents the portion of the overall backup stream that is accessible to the mover without intervening DMA tape manipulation.
[-mover-con-addr-type <address type>]- Mover Connect Type-
This field specifies the type of data connection established by the mover. The data connection can be established locally within a given system or between remote networked systems.
[-mover-con-addr <text>]- Mover Connect Address-
This specifies the endpoint address or addresses that the mover will use when establishing a data connection.
[-mover-con-port <integer>]- Mover Connect Port-
This specifies the TCP/IP port that the mover will use when establishing a data connection.
[-eff-host <host type>]- Effective Host-
This field indicates the host context in which the NDMP session runs. The valid values are: PRIMARY or PARTNER.
[-client-addr <text>]- NDMP Client Address-
This parameter specifies the client's IP address.
[-client-port <integer>]- NDMP Client Port-
This parameter specifies the client's port number.
[-spt-device-id <text>]- SCSI Device ID-
This parameter specifies the SCSI device ID.
[-spt-ha <integer>]- SCSI Host Adapter-
This parameter specifies the SCSI host adapter.
[-spt-scsi-id <integer>]- SCSI Target ID-
This parameter specifies the SCSI target.
[-spt-scsi-lun <integer>]- SCSI LUN ID-
This parameter specifies the SCSI LUN ID.
[-tape-device <text>]- Tape Device-
This parameter specifies the name to identify the tape device.
[-tape-mode <mover mode>]- Tape Mode-
This parameter specifies the mode in which tapes are opened.
[-is-secure-control-connection {true|false}]- Is Secure Control Connection-
This parameter specifies whether the control connection is secure or not.
[-data-backup-mode <text>]- Data Backup Mode-
This parameter specifies whether the mode of data backup is Dump or SMTape.
[-data-path <text>]- Data Path-
This parameter specifies the path of data being backed up.
[-source-addr <text>]- NDMP Source Address-
This parameter specifies the control connection IP address of the NDMP session.
The following example displays all the NDMP sessions on the cluster:
cluster1::> system services ndmp status
Session
Node Id
node-01 17479
node-01 19769
node-02 21118
3 entries were displayed.
The following example shows how to display only the sessions running on node-01:
cluster1::> system services ndmp status -node node-01
Session
Node Id
node-01 17479
node-01 19769
2 entries were displayed.
