qos adaptive-policy-group show
Display a list of adaptive policy groups
The qos adaptive-policy-group show command shows the current settings of the adaptive policy groups on a cluster. You can view the list of adaptive policy groups and also the detailed information about a specific adaptive policy group.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-policy-group <text>]- Name-
Selects the adaptive policy groups that match this parameter value.
Adaptive policy groups define measurable service level objectives (SLOs) that adjust based on volume used space or volume allocated space.
[-vserver <vserver name>]- Vserver-
If this parameter is specified, the command displays information only about the adaptive policy groups with a matching vserver.
[-uuid <UUID>]- Uuid-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified UUID.
[-pgid <integer>]- ID-
If this parameter is specified, the command displays information only about the adaptive policy groups that match the given policy group ID, which is an integer that uniquely identifies the adaptive policy group.
[-expected-iops {<integer>[IOPS[/{GB|TB}]] (default: TB)}]- Expected IOPS-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified minimum expected IOPS per TB or GB.
[-peak-iops {<integer>[IOPS[/{GB|TB}]] (default: TB)}]- Peak IOPS-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified maximum possible IOPS per TB or GB.
[-absolute-min-iops <qos_tput>]- Absolute Minimum IOPS-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified absolute minimum IOPS.
[-peak-iops-allocation {used-space|allocated-space}]- Peak IOPS Allocation-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified peak IOPS allocation policy used to compute the maximum possible IOPS per TB or GB.
[-num-workloads <integer>]- Number of Workloads-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified number of workloads.
The example above displays all adaptive policy groups on the cluster.
cluster1::> qos adaptive-policy-group show
Expected Peak
Name Vserver Wklds IOPS IOPS
extreme clus-1 3 6144IOPS/TB 12288IOPS/TB
p1 vs0 0 50IOPS/TB 100IOPS/TB
p2 vs0 1 50IOPS/TB 100IOPS/TB
p3 vs0 0 50IOPS/TB 100IOPS/TB
p4 vs0 0 50IOPS/TB 100IOPS/TB
p5 vs0 0 50IOPS/GB 100IOPS/GB
performance clus-1 0 2048IOPS/TB 4096IOPS/TB
value clus-1 0 128IOPS/TB 512IOPS/TB
8 entries were displayed.
