snapmirror list-destinations
Display a list of destinations for SnapMirror sources
The snapmirror list-destinations command displays information including the destination endpoints, the relationship status, and transfer progress, for SnapMirror relationships whose source endpoints are in the current Vserver if you are in a Vserver context, or the current cluster if you are in a cluster context. +
The command might display several relationships that have the same source and destination endpoints, but have different relationship IDs. If this is the case, some of the information is stale. It corresponds to relationships that have been deleted on the destination Vserver or cluster, and have not been released yet on the source Vserver or source cluster.
The relationships and the information displayed are controlled by the parameters that you specify. If no parameters are specified, the command displays the following information associated with each SnapMirror relationship whose source endpoint is in the current Vserver if you are in a Vserver context, or the current cluster if you are in a cluster context:
Source path
Relationship Type
Destination Path
Relationship Status
Transfer Progress
Progress Last Updated
Relationship ID
Note the following limitations on the information displayed by the snapmirror list-destinations command:
The
"Relationship Status"field is not valid after the node hosting the source volume joins the cluster quorum, until at least one transfer is performed on the SnapMirror relationship. -
"Transfer Progress"and"Progress Last Updated"fields are only valid if a Snapshot copy transfer is in progress. -
The
"Relationship ID"field is not valid for Vserver SnapMirror relationships. -
The
"Relationship Status","Transfer Progress", and"Progress Last Updated"fields are not valid for FlexGroup relationships, but they are valid for FlexGroup constituent relationships.
The -instance and -fields parameters are mutually exclusive and select the fields that are displayed. The -instance parameter if specified, displays detailed information about the relationships. The -fields parameter specifies what fields should be displayed. The other parameters of the snapmirror list-destinations command, select the SnapMirror relationships for which the information is displayed.
This command is not supported for SnapMirror relationships with non-Data ONTAP endpoints.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command only displays the fields that you have specified. - |
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all relationships selected. - {
[-S, -source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>}]- Source Path -
Selects SnapMirror relationships that have a matching source path name.
[-source-vserver <vserver name>]- Source Vserver -
Selects SnapMirror relationships that have a matching source Vserver name.
[-source-volume <volume name>]- Source Volume }-
Selects SnapMirror relationships that have a matching source volume name.
[-destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>}]- Destination Path -
Selects SnapMirror relationships that have a matching destination path name.
[-destination-vserver <vserver name>]- Destination Vserver -
Selects SnapMirror relationships that have a matching destination Vserver name.
[-destination-volume <volume name>]- Destination Volume }-
Selects SnapMirror relationships that have a matching destination volume name.
[-relationship-id <UUID>]- Relationship ID-
Selects SnapMirror relationships that have a matching relationship identifier. This parameter is not supported for Vserver SnapMirror relationships.
[-type <snapmirrorType>]- Relationship Type-
Selects SnapMirror relationships that have a matching relationship type. Possible values are:
DP
XDP
RST
[-relationship-group-type {none|vserver|infinitevol|consistencygroup|flexgroup}]- Relationship Group Type-
Selects SnapMirror relationships that have a matching relationship group type. Possible values are:
none
vserver
infinitevol
flexgroup
[-policy-type {vault|async-mirror|mirror-vault}]- SnapMirror Policy Type-
Selects SnapMirror relationships that have a matching SnapMirror policy type. Possible values are:
async-mirror
vault
mirror-vault
[-status <mirror status>]- Relationship Status-
Selects SnapMirror relationships that have a matching relationship status. Possible values are:
Idle
Transferring
This parameter is not supported for FlexGroup SnapMirror relationships, but it is supported for FlexGroup constituent relationships.
[-transfer-progress {<integer>[KB|MB|GB|TB|PB]}]- Transfer Progress-
Selects SnapMirror relationships that have a matching transfer progress. This parameter is not supported for Infinite Volume or FlexGroup SnapMirror relationships, but it is supported for FlexGroup constituent relationships.
[-progress-last-updated <MM/DD HH:MM:SS>]- Timestamp of Last Progress Update-
Selects SnapMirror relationships that have a matching transfer progress last updated timestamp. This parameter is not supported for Infinite Volume or FlexGroup SnapMirror relationships, but it is supported for FlexGroup constituent relationships.
[-is-constituent {true|false}]- Constituent Relationship-
Selects SnapMirror relationships that have a matching constituent condition. This parameter is not supported for Vserver, FlexGroup, or FlexGroup constituent SnapMirror relationships.
[-source-volume-node <nodename>]- Source Volume Node Name-
Selects SnapMirror relationships that have a matching source volume node name. For FlexGroup relationships, it is the node which owns the root constituent source volume. This parameter is not supported for Vserver SnapMirror relationships.
[-expand <true>]- Show Constituents of the Group-
Specifies whether to display constituent relationships of Vserver and FlexGroup SnapMirror relationships. By default, the constituents are not displayed.
To display summary information about all relationships whose source endpoints are in the current cluster, type the following command:
cluster1::> snapmirror list-destinations
Progress
Source Destination Transfer Last Relationship
Path Type Path Status Progress Updated ID
vserver1.example.com:dp_s1
DP vserver2.example.com:dp_d1
Idle - - 06b4327b-954f-11e1-af65-123478563412
vserver1.example.com:xdp_s1
XDP vserver2.example.com:xdp_d1
Idle - - a9c1db0b-954f-11e1-af65-123478563412
DP dvserver2.example2.com:
Idle - - -
3 entries were displayed.
To display summary information about all relationships whose source endpoints are in the current Vserver, type the following command:
vserver1.example.com::> snapmirror list-destinations
Progress
2 entries were displayed.
To display detailed information about SnapMirror relationships whose source endpoints are in the current Vserver, type the following command:
vserver1.example.com::> snapmirror list-destinations -instance
Source Path: vserver1.example.com:dp_s1
Destination Path: vserver2.example.com:dp_d1
Relationship Type: DP
Relationship Group Type: none
Relationship Status: Idle
Transfer Progress: -
Progress Last Updated: -
Source Volume Node: node1
Relationship ID: 06b4327b-954f-11e1-af65-123478563412
Source Path: vserver1.example.com:xdp_s1
Destination Path: vserver2.example.com:xdp_d1
Relationship Type: XDP
Source Volume Node: node2
Relationship ID: a9c1db0b-954f-11e1-af65-123478563412
To display summary information about all relationships including constituent relationships whose source endpoints are in the current Vserver, type the following command:
cluster-1::> snapmirror list-destinations -expand
Progress
Path Type Path Status Progress Updated Id
vs1:fg_s1 XDP vs1:fg_d1 - - - 504abc00-70a8-11e6-82be-0050568536d7
vs1:fg_s1__0001
XDP vs1:fg_d1__0001
- - - 5041f2aa-70a8-11e6-82be-0050568536d7
vs1:fg_s1__0002
XDP vs1:fg_d1__0002
- - - 50421733-70a8-11e6-82be-0050568536d7
vs1:fg_s1__0003
XDP vs1:fg_d1__0003
- - - 50421826-70a8-11e6-82be-0050568536d7
vs1:fg_s1__0004
XDP vs1:fg_d1__0004
- - - 504218f0-70a8-11e6-82be-0050568536d7
5 entries were displayed.
