vserver vscan scanner-pool privileged-users show
Display list of privileged users
The vserver vscan scanner-pool privileged-users show command displays the list of privileged users of the Vscan scanner pools belonging to the Vserver. If you do not specify any parameters, the command displays the following information about the scanner pools:
Vserver name
Scanner pool
List of privileged users
This command is not supported for a Vserver with Infinite Volume. |
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about the scanner pools for the specified Vserver.
[-scanner-pool <Scanner pool>]- Scanner Pool-
If you specify this parameter, the command displays information only for the specified scanner pool.
[-privileged-users <Privileged user>,…]- List of Privileged Users-
If you specify this parameter, the command displays information only about the scanner pools that have the specified privileged user or users.
The following example displays the list of privileged users of all scanner pools.
cluster1::> vserver vscan scanner-pool privileged-users show Vserver Scanner Pool Privileged Users --------------- ----------------- -------------------------------------------- Cluster clus cifs\u5 vs1 new cifs\u7 vs1 clus cifs\u5 vs1 p1 cifs\u1, cifs\u2 vs2 clus cifs\u5 vs2 p2 cifs\u2 6 entries were displayed.
