volume qtree statistics-reset
Reset qtree statistics in a volume
This command resets qtree statistics for all qtrees in a volume. This command is not supported on Infinite Volumes.
-vserver <vserver name>- Vserver Name-
This specifies the name of the Vserver on which the volume containing the qtree belongs.
-volume <volume name>- Volume Name-
This specifies the name of the volume containing the qtrees whose statistics you want to reset.
The following example resets statistics for all qtrees on the volume named vol1 on the Vserver named vs0.
cluster1::> volume qtree statistics-reset -vserver vs0 -volume vol1
