      system node image abort-operation
Abort software image 'update' or 'get' operation
The system node image abort-operation command aborts software installation ("update") or download ("get") operation on the specified node.
-node {<nodename>|local}- Node (privilege: advanced)-
This specifies the node on which to abort the operation.
The following example aborts the software installation operation on a node named node1 .
cluster1::> system node image abort-operation -node node1
