system node hardware tape drive show
Displays information about tape drives
This command displays the following information about tape drives:
Node to which the tape drive is attached
Device ID of the tape drive
Description of the tape drive
NDMP path of the tape drive
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Displays detailed information about tape drives on the specified node.
[-device-id <text>]- Device ID-
Selects information about the tape drive that has the specified device ID.
[-description <text>]- Description-
Selects information about the tape drive or drives that have the specified description.
[-wwn <text>]- World Wide Name-
Selects information about the tape drive that has the specified worldwide name.
[-serial-number <text>]- Serial Number-
Selects information about the tape drive that has the specified serial number.
[-ndmp-path <text>,…]- NDMP Path-
Selects information about the tape drive or drives that have the specified NDMP path.
The following example displays information about all tape drives in the cluster:
cluster1::> system node hardware tape drive show
Node Device Id Drive Description NDMP Path
cluster1
brocade-247-198:3.126L1 nrst0l nrst0m nrst0h nrst0a
IBM LTO 4 ULTRIUM rst0l rst0m rst0h rst0a
urst0l urst0m urst0h urst0a
brocade-247-198:3.126L2 nrst1l nrst1m nrst1h nrst1a
IBM LTO 4 ULTRIUM rst1l rst1m rst1h rst1a
urst1l urst1m urst1h urst1a
brocade-247-198:3.126L3 nrst2l nrst2m nrst2h nrst2a
IBM LTO 4 ULTRIUM rst2l rst2m rst2h rst2a
urst2l urst2m urst2h urst2a
brocade-247-198:3.126L4 nrst3l nrst3m nrst3h nrst3a
IBM LTO 4 ULTRIUM rst3l rst3m rst3h rst3a
urst3l urst3m urst3h urst3a
brocade-247-198:3.126L6 nrst5l nrst5m nrst5h nrst5a
SONY SDX-400C rst5l rst5m rst5h rst5a
urst5l urst5m urst5h urst5a
5 entries were displayed.
