network port broadcast-domain rename
Rename a layer 2 broadcast domain
Rename a broadcast domain.
-ipspace <IPspace>- IPspace Name-
The IPspace to which the broadcast domain belongs.
-broadcast-domain <broadcast domain name>- Layer 2 Broadcast Domain-
The name of the broadcast domain.
-new-name <text>- New Name-
The new name of the broadcast domain.
The following example renames the broadcast domain named "mgmt" to "mgmt2" in IPspace "Default".
cluster1::network port broadcast-domain> rename -ipspace Default -broadcast-domain mgmt -new-name mgmt2
