vserver fcp delete
Delete FCP service configuration
Deletes an FCP service of a Vserver. Before you can delete an FCP service, the administration status must be down . Use the vserver fcp modify command to change the administration status.
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver for the FCP service.
cluster1::> vserver fcp delete -vserver vs_1
Deletes the FCP service on Vserver vs_1 .
