cluster ha show
Show high-availability configuration status for the cluster
The cluster ha show command displays the high-availability status of the cluster. Cluster high-availability mode applies only to two-node clusters.
The following example displays the high-availability status for a two-node cluster:
cluster1::> cluster ha show High Availability Configured: true
