ONTAP commands
system controller clus-flap-threshold show
Display the controller cluster port flap threshold
The system controller clus-flap-threshold show command allows the display of the threshold for link flapping counts for all nodes. This threshold would be the number of times the cluster port links for a given node can flap (go down) within a polling period before triggering an alert.
