application volume show
Display application volumes
This command displays the volumes that are part of an application.
[-fields <fieldname>,…] -
Specifies fields that you want included in the output. You can use
-fields ?to display the available fields. - |
[-instance ]} -
Specifies the display of all available fields for each selected volume.
[-vserver <vserver name>]- Vserver (privilege: advanced)-
Selects application volumes belonging to Vservers that match the parameter value.
[-application <text>]- Application (privilege: advanced)-
Selects application volumes that belong to an application that matches the parameter value.
[-volume <volume name>]- Volume (privilege: advanced)-
Selects application volumes whose name matches the parameter value.
[-size {<integer>[KB|MB|GB|TB|PB]}]- Volume Size (privilege: advanced)-
Selects application volumes whose size matches the parameter value.
[-state {online|restricted|offline|force-online|force-offline|mixed}]- Volume State (privilege: advanced)-
Selects application volumes whose state matches the parameter value.
[-application-component <text>]- Application Component (privilege: advanced)-
Selects application volumes that belong to application component that matches the parameter value.
cluster1::> application volume show
Vserver Application Volume State
vs1 app1
vol1 online
vol2 online
vol3 online
app2
vol4 online
vol5 online
vol6 online
vs2 app3
vol7 online
vol8 online
vol9 online
app4
vol10 online
vol11 online
vol12 online
12 entries were displayed.
The example above displays the volumes of all applications in the cluster.
cluster1::> application volume show -vserver vs1 -application app1
vs1 app1
vol1 online
vol2 online
vol3 online
3 entries were displayed.
The example above displays the volumes of application app1 in Vserver vs1.
